Hej,
I’m trying to understand how Vault charm operates, and if it’s capable of using a domain certificate obtained by an external device.
As I understood the documentation, the vault charm can operate in two modes. 1) the self-signed (generate-root-ca). Or, 2) using a signed-csr. The second approach, that requires us to download the csr from the vault, have it signed, then upload the signed information back to the Vault.
In my scenario, I have an external device that obtains a domain certificate from Let’s Encrypt. This is distributed to several nodes in the domain. I’d also like to use the same certificate in the vault. So, that all services under that domain have the same certificate. (+ having a certificate signed in my organization will take days, or longer).
AFAIK, a standard vault would have no problems storing the information [1]. But in the Vault charm, just storing the data isn’t enough right? It has to be stored so that the ‘users/clients’ of the charm can obtain the certificates, in the form required by each ‘user/client’.
So, is possible, to upload use an existing Let’s Encrypt domain certificate, and have Vault distribute it to its clients?
BR/Patrik
[1] https://developer.epages.com/blog/tech-stories/managing-lets-encrypt-certificates-in-vault/
