Testing > Unit testing > Util suite
A util suite is a struct which provides specific setup and teardown behavior as well as useful variables and functions to write unit test suites with.
There are several util suites, among which:
/testing.BaseSuite(testing/base.go)/testing.FakeHomeSuite(testing/environ.go)/testing.FakeJujuHomeSuite(testing/environ.go)- (DEPRECATED)
/juju/testing.JujuConnSuite(juju/testing/conn.go)
The last three have the BaseSuite functionality included through composition. The BaseSuite isolates a user’s home directory from accidental modification (by setting $HOME to "") and errors if there is an attempt to do outgoing HTTP access. It also clears the relevant $JUJU_* environment variables. The BaseSuite is also composed of the core LoggingSuite, and also LoggingSuite from github.com/juju/testing, which brings in the CleanupSuite from the same. The CleanupSuite has functionality around patching environment variables and normal variables for the duration of a test. It also provides a clean-up stack called when the test teardown happens.
If you need additional functionality, you can embed one of the suites below:
BaseSuite
FakeHomeSuite: creates a fake home directory with
~/.sshand fake ssh keys. -
FakeJujuHomeSuite: as above but also sets up a
~/.config/jujuwith a fake model. -
(DEPRECATED) JujuConnSuite: Simulates a controller and an API server as well as a database. Quite heavy weight. Can be useful in that it simulates a Juju environment as closely as possible.
