Problem background
Disclaimer: This may already have been documented somewhere but I haven’t found it. It was tested with Charmcraft 2.1.0 and LXD 5.6.
If your UID/GID is higher than 65535 you’re likely to have issues running charmcraft. This is very typical in enterprise deployments where your machine is using SSSD with an Active Directory backend. Me and @erik-lonroth have seen this many times. In this case, you likely have UID/GID at around 400 million:
$ getent passwd hallback
hallback:*:413906259:413906259:Johan Hallbäck:/home/hallback:/bin/bash
Furthermore, your user isn’t present in /etc/passwd
Problem 1: charmcraft init can’t find your name in /etc/passwd
This one is simple, you just have to specify your full name using charmcraft init --author
$ charmcraft init
Unable to automatically determine author's name, specify it with --author
Full execution log: '/home/hallback/snap/charmcraft/common/cache/charmcraft/log/charmcraft-20221014-153404.969775.log'
$ charmcraft init --author "Johan Hallbäck"
Charmed operator package file and directory tree initialised.
Now edit the following package files to provide fundamental charm metadata and other information:
metadata.yaml
config.yaml
src/charm.py
README.md
Problem 2: charmcraft pack won’t work due to UID/GID ranges in LXD
Running charmcraft pack
will probably end up like this:
$ charmcraft pack
Failed to launch instance 'charmcraft-myfirstcharm-9307267-0-0-amd64'.rchitectures=['amd64'] (may take a while the first time but it's reusable)
* Command that failed: "lxc --project charmcraft launch craft-com.ubuntu.cloud-buildd:22.04 local:charmcraft-myfirstcharm-9307267-0-0-amd64 --config 'raw.idmap=both 413206259 0' --config security.syscalls.intercept.mknod=true"
* Command exit code: 1
* Command output: b'Creating charmcraft-myfirstcharm-9307267-0-0-amd64\n'
* Command standard error output: b'Error: Failed instance creation: Failed creating instance record: Failed initialising instance: Host id is in the range of subids\n'
Full execution log: '/home/hallback/snap/charmcraft/common/cache/charmcraft/log/charmcraft-20221013-155608.626706.log'
The problem is that my UID on the host (above 400 million) is within the range of the container UIDs (above 65536). We also need to make sure that the size of the idmap is big enough for my 400 million UID, or else we’ll get charmcraft errors with lxc file push
later on.
The fix is to modify the default profile of the charmcraft project in LXD.
This is how it can look by default:
$ lxc --project charmcraft profile list
| NAME | DESCRIPTION | USED BY |
| default | Default LXD profile | 1 |
$ lxc --project charmcraft profile show default
config:
boot.autostart: "false"
description: Default LXD profile
devices:
eth0:
nictype: bridged
parent: lxdbr0
type: nic
root:
path: /
pool: lxdstoragepool1
type: disk
used_by:
- /1.0/instances/charmcraft-myfirstcharm-9307267-0-0-amd64?project=charmcraft
NOTE! If you have no project called charmcraft
, run charmcraft pack
once and let it fail first.
For all containers in the project charmcraft
, let the container idmap start beyond your UID. I chose 500 million here, and made the size 500 million also:
$ lxc --project charmcraft profile set default security.idmap.base=500000000
$ lxc --project charmcraft profile set default security.idmap.size=500000000
$ lxc --project charmcraft profile set default security.idmap.isolated=true
The result should look like this:
config:
security.idmap.base: "500000000"
security.idmap.isolated: "true"
security.idmap.size: "500000000"
devices:
eth0:
nictype: bridged
parent: lxdbr0
type: nic
root:
path: /
type: disk
used_by:
Now charmcraft pack
should work just fine for users with high UIDs.
/Johan Hallbäck, Ibeo Automotive Systems GmbH
