Hello everyone. I have some Questions regarding the usage of Blockstorage over Fiberchannel in OpenStack. I’m new to OpenStack and learning actually much of it. I installed Canonical OpenStack on a 4 Node Cluster actually as Prrof of Concept Setup to learn how it works and if it fits our need migrating away from VMware. I kwon that there are several Modules in OpenStack that support Blockstorage over FC; it also can automatically create Zone-Configurations on Brocade and Cisco FC Switches and so on. But actually i don’t find any useful informations about setting up a already to the Hosts mapped FC LUN in general. Maybe someone here can point me in the right direction?
My Setup is Straight forward to the actual Documentation. MAAS Setup with 4 Nodes; in each Node i have 1 SSD for 1 Ceph OSD. Now i want to use the already attached FC-LUN also on each Host → i don’t know how to do that. multipath is active and running on the hosts.
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 55.7M 1 loop /snap/core18/2812
loop1 7:1 0 63.9M 1 loop /snap/core20/2105
loop2 7:2 0 63.9M 1 loop /snap/core20/2182
loop3 7:3 0 87M 1 loop /snap/lxd/27037
loop4 7:4 0 87M 1 loop /snap/lxd/27428
loop5 7:5 0 93.5M 1 loop /snap/mysql-shell/29
loop6 7:6 0 3M 1 loop /snap/prometheus-ovs-exporter/9
loop7 7:7 0 40.4M 1 loop /snap/snapd/20671
loop8 7:8 0 39.1M 1 loop /snap/snapd/21184
sda 8:0 0 119.2G 0 disk
├─sda1 8:1 0 1M 0 part
└─sda2 8:2 0 119.2G 0 part /
sdb 8:16 0 372.6G 0 disk
└─ceph--a58d4728--99df--4faa--9416--b2ac416ed781-osd--block--a58d4728--99df--4faa--9416--b2ac416ed781 253:0 0 372.6G 0 lvm
sdc 8:32 0 40T 0 disk
└─mpatha 253:1 0 40T 0 mpath
sdd 8:48 0 40T 0 disk
sde 8:64 0 40T 0 disk
sdf 8:80 0 40T 0 disk
sdg 8:96 0 40T 0 disk
sdh 8:112 0 40T 0 disk
sdi 8:128 0 40T 0 disk
sdj 8:144 0 40T 0 disk
sr0 11:0 1 1024M 0 rom
sda is the Boot Disk, sdb the Ceph Disk and sdc to sdj is the FC LUN mapped under /dev/mapper/mpatha
multipath -ll
mpatha (36c8a7761004f8b7290000b00000451) dm-1 VENDOR,TYPE
size=40T features='1 queue_if_no_path' hwhandler='1 alua' wp=rw
|-+- policy='service-time 0' prio=50 status=active
| |- 1:0:2:1 sde 8:64 active ready running
| |- 1:0:3:1 sdf 8:80 active ready running
| |- 8:0:1:1 sdh 8:112 active ready running
| `- 8:0:3:1 sdj 8:144 active ready running
`-+- policy='service-time 0' prio=10 status=enabled
|- 1:0:0:1 sdd 8:48 active ghost running
|- 1:0:1:1 sdc 8:32 active ghost running
|- 8:0:0:1 sdg 8:96 active ghost running
`- 8:0:2:1 sdi 8:128 active ghost running
Do i only have to change the cinder.conf from
cinder:
block-device: None
glance-api-version: 2
to
cinder:
block-device: /dev/mapper/mpatha
→ How to integrate this Block Device in the juju cinder-configuration and apply the config-changes?
→ How can i map a unique LUN-ID to a unique /dev/mapper/unique-name so that it is persistent on all attached Hosts?
→ Can i define Storage Grades or Labels so that it is possible a User can book e.g. NVMe Disk Storage and other users only need HDD Storage and OpenStack automatically uses the correct Storage Locations and Hosts in Background?
Thanks!
