Hi there!
The latest addition to jhack, imatrix, has just received a round of updates.
- Support for peer relations in
view:jhack imatrix view -pwill fill the diagonal of the matrix with peer relation name and interface information. Just for completeness.
- Support for multiple relations on an endpoint:
imatrixused to basically ignore the endpoint name and focus on the interface. It asked: can this charm relate to this other charm via ? Therefore, it ignored (or panicked) whenever two charms had more than one (possible) relation using the same interface. Now that’s a thing of the past: each entry in the table will display not only the interface (and the number of relations using it), but a full list ofprovider_endpoint --> [interface] --> requirer_endpointtriplets.
For example:
This tells us that traefik:ingress-per-unit can be bound (and is currently related!) to prometheus:ingress using the shared ingress_per_unit interface.
The red entry tells us that there is one more available relation, but that’s currently inactive.
imatrix view with cos-lite:
Have fun!
