Hi,
I have deployed my custom cinder backend using the cookie cutter template. Everything is working perfectly fine (this is the link btw) except when the charm tries to do an status update. After the charm has been deployed and several minutes have passed by, if I do a juju status this is what I see.
cinder 20.3.1 active 3 cinder yoga/stable 664 no Unit is ready
cinder-e590 waiting 3 cinder-e590 0 no Charm configuration in progress
cinder-hacluster 2.1.2 active 3 hacluster 2.4/stable 131 no Unit is ready and clustered
cinder-mysql-router 8.0.35 active 3 mysql-router 8.0/stable 111 no Unit is ready
cinder/0 active idle 0 172.16.14.64 8776/tcp Unit is ready
cinder-e590/2 waiting idle 172.16.14.64 Charm configuration in progress
cinder-hacluster/2 active idle 172.16.14.64 Unit is ready and clustered
cinder-mysql-router/2 active idle 172.16.14.64 Unit is ready
cinder/1* active idle 1 172.16.14.65 8776/tcp Unit is ready
cinder-e590/0* waiting idle 172.16.14.65 Charm configuration in progress
cinder-hacluster/0* active idle 172.16.14.65 Unit is ready and clustered
cinder-mysql-router/0* active idle 172.16.14.65 Unit is ready
cinder/2 active idle 2 172.16.14.68 8776/tcp Unit is ready
cinder-e590/1 waiting idle 172.16.14.68 Charm configuration in progress
cinder-hacluster/1 active idle 172.16.14.68 Unit is ready and clustered
cinder-mysql-router/1 active idle 172.16.14.68 Unit is ready
As you can see, the charm status changes to configuration in progress (I guess because there is no update hook. I went to check the logs from the cinder-e590 unit (my charm) and I can see this. This makes me think that it did update successfully so I don’t know how to continue now, because the actual storage backend configuration got written to the /etc/cinder/cinder.conf file. I’m not sure what the update should do and why it would be writing down the configuration again.
> 2024-01-03 18:58:47 INFO juju.worker.uniter.operation runhook.go:186 ran "update-status" hook (via hook dispatching script: dispatch)
> 2024-01-03 19:03:37 INFO unit.cinder-e590/2.juju-log server.go:325 Updating status
> 2024-01-03 19:03:37 INFO unit.cinder-e590/2.juju-log server.go:325 Status updated
Thank you in advance.
