Unlist or remove tracks from Charmhub [Identity charms]
Hello, could you please unlist/remove the following tracks from Charmhub?
  1. Kratos: https://charmhub.io/kratos
0.1/edge
0.2/edge
0.3/edge
0.4/edge
  1. Hydra: Charmhub | Deploy Hydra using Charmhub - The Open Operator Collection
0.1/edge
0.2/edge
0.3/edge
  1. Identity Platform Login UI Operator: Charmhub | Deploy Identity Platform Login Ui Operator using Charmhub - The Open Operator Collection
0.999/edge
0.1/edge
0.2/edge
0.3/edge
0.4/edge
  1. Kratos External Idp Integrator: Charmhub | Deploy Kratos External Idp Integrator using Charmhub - The Open Operator Collection
0.1/edge
0.2/edge
0.3/edge
Thank you
Hi,
Tracks cannot be “removed” per say. We can offer alternatives based on what you actually want to achieve. The recommended approach is to close all risks for each track, example:
for risk in stable candidate beta edge; do charmcraft close kratos 0.1/$risk; done
The tracks still exist technically but since you closed all the channels, nobody will be able see nor install from them.
Please give this a try and let me know if this helps,
Barrett
