Unique machine identifier - is there such a thing?
We are implementing a CMDB and want to link information to machines in juju.
For this purpose, I need a stable way to have a unique identifier (database key) for a juju-machines. Ideally the machines information would be available in the juju controller database.
If there is a “machine key”, I could use that to database join with data from of our other collected information.
:cross_mark: What I cannot use as universal machine identity
These do not survive cloning, provider differences, or match between Juju and your external system:
Candidate Problem
Juju instance-id Only exists when Juju is managing the machine; LXC clones produce new names
LXD container name Only for LXC; not persistent outside LXD
Nonce (agent.conf) Only used during provisioning; random; never reused
IP address, DNS name Not stable or unique
MAC address Reassigned on reboot, clone, bridge changes
Hostname User can change it; Juju changes it too
EC2 instance-id Valid only in EC2, not on LXC or bare metal
Node UUID (dmidecode) Not accessible inside LXC, and can be duplicated in VMs
I had some hopes for the The instance_id ? , but (source: chatGPT):
This is the machine’s provider ID, coming from:
  • LXD → container name
  • EC2 → instance ID
  • MAAS → node system ID
  • Manual → generated “manual::UUID”
  • VMware → VM UUID
This is stable only as long as the provider persists, but its not unique for manual clouds for example.
:check_mark: Unique in its cloud provider :cross_mark: Not universal across providers :cross_mark: Not accessible from inside the machine without Juju :cross_mark: Not stable when machines are recycled or rebuilt
At this point - the only option I seem to be able to use “fairly” consistent would be the hostname or dns-name as given from “juju show-machine”.
Is there anyone that would have a better idea of a “unique machine identifier” which also is possible to extract outside of juju?
