Hi there!
I’m trying to deploy Juju bootstrapping over microk8s behind a corporate proxy. I’ve checked several threads but still I’m unable to fix “juju deploy”:
$ juju deploy kubeflow
ERROR resolving with preferred channel: Post "https://api.charmhub.io/v2/charms/refresh": x509:
certificate signed by unknown authority
I’m on Ubuntu 22.04.2 LTS
I’ve followed several steps - picked from various topics in the forum. Can anyone help me figure this out?
I prepared a bootstrap.yaml with all my proxy vars AND several ca-certs (full corporate cert chain) as my proxy will tamper with SSL:
apt-http-proxy: "my.corporate.proxy:port"
apt-https-proxy: "my.corporate.proxy:port"
apt-no-proxy: "my.corporate.domain,local,localhost,::1,127.0.0.0/8,10.0.0.0/8,192.168.0.0/16,172.16.0.0/16"
juju-http-proxy: "my.corporate.proxy:port"
juju-https-proxy: "my.corporate.proxy:port"
juju-no-proxy: "my.corporate.domain,local,localhost,::1,127.0.0.0/8,10.0.0.0/8,192.168.0.0/16,172.16.0.0/16"
snap-http-proxy: "my.corporate.proxy:port"
snap-https-proxy: "my.corporate.proxy:port"
cloudinit-userdata: |
ca_certs:
trusted:
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
I bootstrap apparently OK with:
$ juju bootstrap --config=bootstrap.yaml --model-default=bootstrap.yaml microk8s micro
Creating Juju controller "micro" on microk8s/localhost
Bootstrap to Kubernetes cluster identified as microk8s/localhost
Fetching Juju Dashboard 0.8.1
Creating k8s resources for controller "controller-micro"
Starting controller pod
Bootstrap agent now started
Contacting Juju controller at 10.152.183.63 to verify accessibility...
Bootstrap complete, controller "micro" is now available in namespace "controller-micro"
Now you can run
juju add-model <model-name>
to create a new model to deploy k8s workloads.
Some additional context:
Snap proxies are properly set up via /etc/environment and /var/snap/microk8s/current/args/containerd-env:
HTTP_PROXY=my.corporate.proxy:port
HTTPS_PROXY=my.corporate.proxy:port
NO_PROXY=my.corporate.domain,local,localhost,::1,127.0.0.0/8,10.0.0.0/8,192.168.0.0/16,172.16.0.0/16
http_proxy=my.corporate.proxy:port
https_proxy=my.corporate.proxy:port
no_proxy=my.corporate.domain,local,localhost,::1,127.0.0.0/8,10.0.0.0/8,192.168.0.0/16,172.16.0.0/16
Both microk8s and juju deployed and running just fine (snap install --classic microk8s && snap install --classic juju):
snap list | grep -e microk8s -e juju
juju 2.9.42 22345 2.9/stable canonical** classic
microk8s v1.26.4 5219 1.26/stable canonical** classic
microk8s working just fine & with extra features enabled:
$ kubectl get all --all-namespaces
NAMESPACE NAME READY STATUS RESTARTS AGE
minio-operator pod/minio-operator-67dcf6dd7c-xn7fl 0/1 Pending 0 109m
kube-system pod/kubernetes-dashboard-dc96f9fc-bw56h 1/1 Running 2 (78m ago) 116m
kube-system pod/dashboard-metrics-scraper-7bc864c59-4xxmz 1/1 Running 2 (78m ago) 116m
kube-system pod/hostpath-provisioner-69cd9ff5b8-tx2w4 1/1 Running 2 (78m ago) 116m
istio-system pod/istiod-558cdbcbff-7s8wx 1/1 Running 1 (78m ago) 110m
minio-operator pod/console-66c4b79fbd-zg26q 1/1 Running 1 (78m ago) 109m
container-registry pod/registry-77c7575667-q66vh 1/1 Running 2 (78m ago) 116m
kube-system pod/calico-kube-controllers-79568db7f8-l678k 1/1 Running 2 (78m ago) 125m
kube-system pod/coredns-6f5f9b5d74-5fff8 1/1 Running 2 (78m ago) 117m
kube-system pod/calico-node-8vztk 1/1 Running 2 (78m ago) 125m
kube-system pod/metrics-server-6f754f88d-xgpng 1/1 Running 2 (78m ago) 116m
istio-system pod/istio-ingressgateway-5f57c68988-qwpnc 1/1 Running 1 (78m ago) 110m
istio-system pod/istio-egressgateway-6b957f5b7d-kvjpg 1/1 Running 1 (78m ago) 110m
minio-operator pod/minio-operator-67dcf6dd7c-qz2nc 1/1 Running 4 (77m ago) 109m
minio-operator pod/microk8s-ss-0-0 1/1 Running 4 (77m ago) 109m
NAMESPACE NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
default service/kubernetes ClusterIP 10.152.183.1 <none> 443/TCP 126m
kube-system service/kube-dns ClusterIP 10.152.183.10 <none> 53/UDP,53/TCP,9153/TCP 117m
container-registry service/registry NodePort 10.152.183.227 <none> 5000:32000/TCP 117m
kube-system service/metrics-server ClusterIP 10.152.183.49 <none> 443/TCP 117m
kube-system service/kubernetes-dashboard ClusterIP 10.152.183.17 <none> 443/TCP 117m
kube-system service/dashboard-metrics-scraper ClusterIP 10.152.183.152 <none> 8000/TCP 117m
istio-system service/istiod ClusterIP 10.152.183.214 <none> 15010/TCP,15012/TCP,443/TCP,15014/TCP 111m
istio-system service/istio-egressgateway ClusterIP 10.152.183.128 <none> 80/TCP,443/TCP 110m
istio-system service/istio-ingressgateway LoadBalancer 10.152.183.67 <pending> 15021:30010/TCP,80:31753/TCP,443:30371/TCP,31400:30318/TCP,15443:30661/TCP 110m
minio-operator service/operator ClusterIP 10.152.183.220 <none> 4222/TCP,4221/TCP 109m
minio-operator service/console ClusterIP 10.152.183.104 <none> 9090/TCP,9443/TCP 109m
minio-operator service/minio ClusterIP 10.152.183.183 <none> 80/TCP 109m
minio-operator service/microk8s-console ClusterIP 10.152.183.234 <none> 9090/TCP 109m
minio-operator service/microk8s-hl ClusterIP None <none> 9000/TCP 109m
NAMESPACE NAME DESIRED CURRENT READY UP-TO-DATE AVAILABLE NODE SELECTOR AGE
kube-system daemonset.apps/calico-node 1 1 1 1 1 kubernetes.io/os=linux 126m
NAMESPACE NAME READY UP-TO-DATE AVAILABLE AGE
kube-system deployment.apps/calico-kube-controllers 1/1 1 1 126m
kube-system deployment.apps/coredns 1/1 1 1 117m
kube-system deployment.apps/dashboard-metrics-scraper 1/1 1 1 117m
kube-system deployment.apps/metrics-server 1/1 1 1 117m
kube-system deployment.apps/kubernetes-dashboard 1/1 1 1 117m
kube-system deployment.apps/hostpath-provisioner 1/1 1 1 117m
container-registry deployment.apps/registry 1/1 1 1 117m
istio-system deployment.apps/istiod 1/1 1 1 111m
minio-operator deployment.apps/console 1/1 1 1 109m
istio-system deployment.apps/istio-ingressgateway 1/1 1 1 110m
istio-system deployment.apps/istio-egressgateway 1/1 1 1 110m
minio-operator deployment.apps/minio-operator 1/2 2 1 109m
NAMESPACE NAME DESIRED CURRENT READY AGE
kube-system replicaset.apps/calico-kube-controllers-79568db7f8 1 1 1 125m
kube-system replicaset.apps/coredns-6f5f9b5d74 1 1 1 117m
kube-system replicaset.apps/dashboard-metrics-scraper-7bc864c59 1 1 1 116m
kube-system replicaset.apps/metrics-server-6f754f88d 1 1 1 116m
kube-system replicaset.apps/kubernetes-dashboard-dc96f9fc 1 1 1 116m
kube-system replicaset.apps/hostpath-provisioner-69cd9ff5b8 1 1 1 116m
container-registry replicaset.apps/registry-77c7575667 1 1 1 116m
istio-system replicaset.apps/istiod-558cdbcbff 1 1 1 110m
minio-operator replicaset.apps/console-66c4b79fbd 1 1 1 109m
istio-system replicaset.apps/istio-ingressgateway-5f57c68988 1 1 1 110m
istio-system replicaset.apps/istio-egressgateway-6b957f5b7d 1 1 1 110m
minio-operator replicaset.apps/minio-operator-67dcf6dd7c 2 2 1 109m
NAMESPACE NAME READY AGE
minio-operator statefulset.apps/microk8s-ss-0 1/1 109m
Anyone can help me spot the problem here?
