I followed this blog post to try and deploy Octavia on Openstack created with Juju and Maas.
Everything seems to be working but when I try to create a load balancer the amphora instance fails. I’ve tried creating them manually with the Openstack CLI, via the Openstack dashboard and via a Kubernetes cluster that was deployed on Openstack with Juju. The problem may be with Openstack but I thought I’d start here first.
I thought maybe the issue was with creating the instance in Nova so I watched the logs there and everything seems fine.
Nova Log - https://gist.github.com/2stacks/152918ec7f7d60c61ba17d5809211c97
The only place I see an indication of an issue is in the Octavia worker logs. There seems to be a clear indication that the controller can’t reach the newly created instance over the lb-mgmt-net.
2019-08-24 16:23:37.528 675855 WARNING octavia.amphorae.drivers.haproxy.rest_api_driver [-] Could not connect to instance. Retrying.: requests.exceptions.ConnectionError: HTTPSConnectionPool(host='fc00:8f36:122:78d8:f816:3eff:fe35:60e1', port=9443): Max retries exceeded with url: /0.5/info (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7fbc2549d048>: Failed to establish a new connection: [Errno 111] Connection refused',))
2019-08-24 16:23:42.585 675855 ERROR octavia.amphorae.drivers.haproxy.exceptions [-] Amphora agent returned unexpected result code 404 with response {'error': '404 Not Found: The requested URL was not found on the server. If you entered the URL manually please check your spelling and try again.', 'http_code': 404}
2019-08-24 16:23:43.013 675855 WARNING octavia.controller.worker.controller_worker [-] Task 'STANDALONE-octavia-create-amp-for-lb-subflow-octavia-amp-compute-connectivity-wait' (1858607d-f808-494f-8ead-8e4bc012a3e2) transitioned into state 'FAILURE' from state 'RUNNING'
Octavia Log - https://gist.github.com/2stacks/736d6b36f97cec0dc05025a7b198bdb2
I verified that all of the necessary networks, security groups, flavors etc. that are created when running
juju run-action --wait octavia/0 configure-resources
have been created in Openstack as expected. I also double check that the Octavia controller can reach other resources on the IPv6 lb-mgmt-net.
root@juju-9e01a5-0-lxd-10:/var/log/octavia# ping fc00:8f36:122:78d8::1
PING fc00:8f36:122:78d8::1(fc00:8f36:122:78d8::1) 56 data bytes
64 bytes from fc00:8f36:122:78d8::1: icmp_seq=1 ttl=64 time=1.69 ms
64 bytes from fc00:8f36:122:78d8::1: icmp_seq=2 ttl=64 time=0.181 ms
root@juju-9e01a5-0-lxd-10:/var/log/octavia# ping fc00:8f36:122:78d8:f816:3eff:fe05:884c
PING fc00:8f36:122:78d8:f816:3eff:fe05:884c(fc00:8f36:122:78d8:f816:3eff:fe05:884c) 56 data bytes
64 bytes from fc00:8f36:122:78d8:f816:3eff:fe05:884c: icmp_seq=1 ttl=64 time=0.525 ms
64 bytes from fc00:8f36:122:78d8:f816:3eff:fe05:884c: icmp_seq=2 ttl=64 time=0.180 ms
I’m pretty much at a loss for where to look next. Any advice will be greatly appreciated.
