Ubuntu Manpages Documentation
Ubuntu Manpages is a site which contains thousands of dynamically generated manuals, extracted from every support version of Ubuntu and updated on a regular basis.
Basic Usage
Assuming you have access to a bootstrapped Juju controller, you can deploy the charm with:
❯ juju deploy ubuntu-manpages
The charm accepts only one configuration option: releases, which is a comma-separated list of Ubuntu releases to include in the manpages, which you can adjust like so:
❯ juju config ubuntu-manpages releases="questing, plucky, oracular, noble"
When a new configuration is applied, the charm will automatically update the manpages to include the new releases, and purge any releases that are present on disk from a previous configuration, but no longer specified.
To update the manpages, you can use the provided Juju Action:
❯ juju run ubuntu-manpages/0 update-manpages
Integrating with an ingress / proxy
The charm supports integrations with ingress/proxy services using the ingress relation. To test this:
# Deploy the charms
❯ juju deploy traefik-k8s --trust --config external-hostname=manpages.internal
# Create integrations
❯ juju integrate ubuntu-manpages traefik-k8s
# Test the proxy integration
❯ curl -k -H "Host: manpages.internal" https://<traefik-ip>/<model-name>-ubuntu-manpages
For more information, see the Github Repository.
