What’s changing
When using juju you can select the operating system you wish to deploy a workload to by specifying a series (e.g. --series focal) or a base --base ubuntu@20.04).
In Juju 4.0, we are removing the concept of a series. So users will have to use bases.
WHY THE CHANGE?
A series is an Operating System’s code name. For example, ‘focal’ and ‘jammy’ are both series. However, series do not translate well outside of the Ubuntu world and cannot be predicted ahead of time.
Bases fix this by separating an operating system into the distro name and channel, separated by an ‘@’. For example, the series focal is equivalent to the base ubuntu@20.04. The series jammy is equivalent to the base ubuntu@22.04.
Specifically:
The
jujuCLI andjuju-metadataplugin will no longer recognise the flags--seriesor--bootstrap-series. Users should use--baseor--bootstrap-baseinstead. -
Juju will ignore
serieskeys in bundles. These keys should be replaced bybasefor applications + machines ordefault-basefor top-level bundle default operating systems. -
Juju will ignore the
serieskey in charm metadata. NOTE: This is already the case for all charms built withcharmcraft. -
Juju pre-series-upgrade hook will no longer expose
JUJU_TARGET_BASE. See more. -
More TBA
Who is this likely to affect?
Juju users who drive
jujuvia a script: Ensure your scripts do not use--seriesor--bootstrap-series. -
Juju users who deploy local charms: Ensure your local charms have been built with
charmcraftbefore deployment. -
Bundle authors: Ensure you bundles + overlays include
default-basein instead of (or as well as)seriesat the top level, andbaseinstead of (or as well as)seriesin applications and machines -
Charm authors who use
JUJU_TARGET_SERIESinpre-series-upgradehook. See more. -
More TBA
Is anything changing in Juju 3.x?
Series is being deprecated in 3.x. Juju will keep compatibility so your current scripts and/or charms should not break, however you may see deprecation warnings when using --series for instance
The only exception to this is Juju will not recognise Ubuntu series after noble.
This means that if Ubuntu 24.10 has codename observant, --series observant will fail. Users will have to use --base ubuntu@24.10 to deploy to this OS.
