Transfer Ownership of `blackbox-exporter`
Hi team,
I understand that teams on Charmhub are being deprecated. With that said, would be possible to change ownership of the blackbox-exporter charm to the Observability LP team until the deprecation happens?
If it’s not possible, then would it be possible to change the owners of said charm to the same owners as the Avalanche charm?
Thanks
Hello,
Looks like the Avalanche charm is owned by the Observability LP team.
We can transfer to the team account, as that is still working, but let me point out that it is already deprecated. What do you think of using this opportunity to try the new permission model based on collaborators?
Regards
Hi Guillermo,
I’d be open to adding the collaborators. Would that need to happen through the Sheets form? Meaning I can add “[charm] blackbox-exporter” to the “Form” tab, along with the LP and Store usernames?
Thanks
Hi, No need to do it via the spreadsheet. As you are the owner of the charm, you can add collaborators via the collaboration tab: https://charmhub.io/blackbox-exporter/collaboration If you want to change ownership and be like the current observability LP team, you will need a team account to transfer it. It could be an account tied to an email alias, a mailing list (which is not recommended but easier) or some other variation. Regards
Perfect, I’ve sent invite links using the Charmhub UI. Thanks for the info!
