Our docs have moved to a new home!
Please update your bookmarks, and contact us if you have any questions.
This feature is available in traefik-k8s starting from revision 206.
In order to enable BasicAuth in traefik-k8s you will need to:
Generate a user string
First you will need to generate a user string with the right format:
<username>:<hashed-password>
where the password must be hashed with either MD5, SHA1, or BCrypt.
We recommend using htpasswd to generate the user string:
(on ubuntu)
$ sudo apt-get install apache2-utils
$ htpasswd -nbB YOUR_USERNAME YOUR_PASSWORD
For example, running with `admin/admin:
$ htpasswd -nbB admin adminadmin:$2y$05$ChsVYFWoLO7YbNnRZSS2IeLcKzL1jgfdOdCfyhtz4tcPOvmTkQYPy
TIP: Use a strong password.
Pass the user string to traefik-k8s
$ juju config traefik-k8s basic_auth_user='<YOUR_USER_STRING>'
Remember to escape the user string! The hash can contain some odd characters that may confuse your shell.
Wait for traefik to process the action and ta-da! you should now have enabled BasicAuth. Any url you try to access through this traefik instance will request the username/password combination you chose.
We don’t yet support multiple users or per-route auth. Need that? Let us know! For the time being, you can consider deploying multiple traefiks to segment your namespace with separate user domains.
