Hello,
Could you please update the superset-k8s charm with the following:
- Add 6/edge and 6/stable channels
- Remove 6/beta and latest/beta channels
Hello,
Hi,
You should be able to release the desired superset-k8s revision to the 6/edge and 6/stable channels with a charmcraft release, provided you are a member in the Commercial Systems team.
Channels 6/beta and latest/beta can be closed if desired with charmcraft close as well.
Let me know if you need anything else.
Thanks,
Deep
