Hello,
we’d like to request bobcat/stable track for neutron-dynamic-routing charm
Thanks.
Hello,
Thanks.
Hi,
The bobcat track has successfully been created for the neutron-dynamic-routing charm.
Thanks,
Odysseus
Thanks for quick resolution @odysseus-k. However I did made a mistake. I should’ve requested 2023.2 instead of bobcat, to be in line with rest of the Openstack charms. Would it be possible to rename bobcat to 2023.2 ?
Oh, I see. Renaming is not possible but assuming you’ve not used bobcat so far, you can keep it “closed” (i.e. not releasing anything to it) and we can create 2023.2 for you to use?
Yup, thanks, that sounds good. bobcat was not used.
Hi,
It seems this was already done as part of this previous request. 2023.2 is available for use.
Thanks,
Odysseus
Oh, I wasn’t aware of this…thank you and sorry for all the fuss.
