Environment Setup
This is part of the TLS Certificates Operator Tutorial. Please refer to this page for more information and the overview of the content.
Minimum requirements
Before we start, make sure your machine meets the following requirements:
- Ubuntu 22.04 (Jammy) or later.
- 8GB of RAM.
- 2 CPU threads.
- Access to the internet for downloading the required snaps and charms.
Multipass environment
Multipass is a quick and easy way to launch virtual machines running Ubuntu. It uses “cloud-init” standard to install and configure all the necessary parts automatically.
Let’s install Multipass from snap and launch a new VM using “charm-dev” cloud-init config:
sudo snap install multipass && \
multipass launch --cpus 4 --memory 8G --disk 30G --name my-vm charm-dev # tune CPU/RAM/HDD accordingly to your needs
Note: all ‘multipass launch’ params are described here.
Multipass list of commands is short and self-explanatory, e.g. show all running VMs:
multipass list
As soon as new VM started, enter inside using:
multipass shell my-vm
Note: if at any point you’d like to leave Multipass VM, enter Ctrl+d or type exit.
All the parts have been pre-installed inside VM already, like MicroK8s and Juju (the files /var/log/cloud-init.log and /var/log/cloud-init-output.log contain all low-level installation details). The Juju controller can work with different models; models host applications such as TLS Certificates Operator. Set up a specific model for TLS Certificates Operator named tutorial:
juju add-model tutorial
You can now view the model you created above by entering the command juju status into the command line. You should see the following:
tutorial charm-dev microk8s/localhost 3.1.5 unsupported 11:56:38+01:00
Model "admin/tutorial" is empty.
