The Juju team is happy to announce that the Juju Terraform provider v0.15.0 was released on 17 Oct 2024!
Thanks to all the contributors including @anvial @hmlanigan.
Update the provider version:
terraform {
required_providers {
juju = {
source = "juju/juju"
version = "~=0.15.0"
LINKS:
NOTES:
- This release requires juju controller version 2.9.49 or later juju.
- This release uses juju client api code from the juju 3.5.1 release.
- JAAS login enhancements requires Juju controller version 3.5.0 or higher.
- Juju secrets support requires Juju controller version 3.4.0 or higher.
What’s Changed
- feat: add jaas validators by @kian99 in feat: add jaas validators by kian99 · Pull Request #541 · juju/terraform-provider-juju · GitHub
- feat: add generic jaas access resource by @kian99 in feat: add generic jaas access resource by kian99 · Pull Request #544 · juju/terraform-provider-juju · GitHub
- feat: add jaas client by @kian99 in https://github.com/juju/terraform-provider-juju/pull/540
- feat: jaas integration tests by @kian99 in feat: jaas integration tests by kian99 · Pull Request #561 · juju/terraform-provider-juju · GitHub
- feat: add “avoid jaas” validator to existing resources by @kian99 in feat: add "avoid jaas" validator to existing resources by kian99 · Pull Request #569 · juju/terraform-provider-juju · GitHub
- feat: improve test speed by @kian99 in feat: improve test speed by kian99 · Pull Request #560 · juju/terraform-provider-juju · GitHub
- feat: JAAS groups schema and CRUD by @pkulik0 in https://github.com/juju/terraform-provider-juju/pull/570
- test: bring canary test up to date with test_integration. by @hmlanigan in test: bring canary test up to date with test_integration. by hmlanigan · Pull Request #586 · juju/terraform-provider-juju · GitHub
- feat: add jaas group access resource by @kian99 in feat: add jaas group access resource by kian99 · Pull Request #587 · juju/terraform-provider-juju · GitHub
- feat: add jaas offer access resource by @kian99 in feat: add jaas offer access resource by kian99 · Pull Request #584 · juju/terraform-provider-juju · GitHub
- feat: add jaas service account access resource by @kian99 in feat: add jaas service account access resource by kian99 · Pull Request #591 · juju/terraform-provider-juju · GitHub
- fix: fix id name in SchemaChanges.yml by @hmlanigan in fix: fix id name in SchemaChanges.yml by hmlanigan · Pull Request #595 · juju/terraform-provider-juju · GitHub
- feat: add jaas controller access resource by @kian99 in feat: add jaas controller access resource by kian99 · Pull Request #590 · juju/terraform-provider-juju · GitHub
- feat: add jaas resource docs by @kian99 in feat: add jaas resource docs by kian99 · Pull Request #594 · juju/terraform-provider-juju · GitHub
- feat: merge jaas resources feature branch by @kian99 in https://github.com/juju/terraform-provider-juju/pull/597
- revert: change to use self hosted runners by @hmlanigan in revert: change to use self hosted runners by hmlanigan · Pull Request #600 · juju/terraform-provider-juju · GitHub
- feat(clouds): add initial implementation for clouds client by @anvial in feat(clouds): add initial implementation for clouds client by anvial · Pull Request #593 · juju/terraform-provider-juju · GitHub
- feat: add computed uuid to model resource by @hmlanigan in feat: add computed uuid to model resource by hmlanigan · Pull Request #599 · juju/terraform-provider-juju · GitHub
- feat(cloud): implement CRUD functions for Kubernetes cloud resource by @anvial in https://github.com/juju/terraform-provider-juju/pull/598
- fix(cloud): resolve acceptance test issues by removing model by @anvial in fix(cloud): resolve acceptance test issues by removing model by anvial · Pull Request #609 · juju/terraform-provider-juju · GitHub
New Contributors
- @pkulik0 made their first contribution in https://github.com/juju/terraform-provider-juju/pull/570
Full Changelog: Comparing v0.14.0...v0.15.0 · juju/terraform-provider-juju · GitHub
