The Juju team is happy to announce that the Juju Terraform provider v0.11.0 was released on 18 March 2024!
Thanks to all the contributors including @alesstimec @amandahla and @gboutry.
Update the provider version:
terraform {
required_providers {
juju = {
source = "juju/juju"
version = "~=0.11.0"
LINKS:
BUG FIXES:
NOTES:
- This release requires juju controller version 2.9.47 or later juju.
- This release uses juju client api code from the juju 3.3.0 release.
ENHANCEMENTS:
- Add resource revisions for juju_application. This is similar to
juju deploy <charm> --resource <name>:#andjuju attach-resource <application> <name>:#. By @alesstimec in #427 - Add kvm and/or lxd machines via the juju_machine resource. This is similar to
juju add-machine lxdandjuju add-machine kvm:0commands. By @amandahla in #378 - Use the DeployFromRevision API endpoint from juju for application deployments with juju 3.3+. By @hmlanigan in #409
- Add space support for the juju_application resources. You can now specify endpoint bindings for applications. This is similar to
juju deploy --bindandjuju bindcommands. By @gboutry in #418
BUG FIXES:
- Fix upgrade charm revision for application resources by @hmlanigan in #414
- Fixes Config/Revision update ordering. by @anvial in #407
- Adds error check to ReadModel function by @anvial in #416
- Add info about
plangeneratorto README. by @anvial in #429 - Update retry to improve machine placement on read and introduce internal/juju unit tests with mocking by @hmlanigan in #433
