Testing Microstack on 4 Servers - Multinode
Hi all,
I want to try out Microstack on 4 HP Servers as an alternative for Vmware to create Vms and wondering if anyone had any ideas where I went wrong, tried it several times now, from fresh.
I’ve been following https://microstack.run/docs/multi-node
I installed Ubuntu and configured bond 0 with Management IP - 10.0.1.130\24 which is NAT’d to the internet. Bond 1 with Public IP range for use with VMs.
Set the host names and setup UFW, checked pings etc.
sudo snap install openstack --channel 2024.1/edge sunbeam prepare-node-script | bash -x && newgrp snap_daemon sunbeam cluster bootstrap --role control --role compute --role storage
I said no to proxy access and set IP range (10.0.1.135-10.0.1.154) for MetalLB
All goes fine and it gets stuck on Deploying Openstack Control Plane to Kubernetes (this may take a while) … waiting for services to come online (21/32)
happens each time, I can see the below output shows lots of services are not installing / pending, how would I now move forward with this ?
Model Controller Cloud/Region Version SLA Timestamp openstack sunbeam-controller sunbeam-microk8s/localhost 3.4.4 unsupported 11:29:11Z
SAAS Status Store URL microceph active local admin/controller.microceph
App Version Status Scale Charm Channel Rev Address Exposed Message certificate-authority active 1 self-signed-certificates latest/beta 155 10.152.183.118 no cinder waiting 1 cinder-k8s 2024.1/edge 85 10.152.183.245 no installing agent cinder-ceph waiting 1 cinder-ceph-k8s 2024.1/edge 82 10.152.183.127 no installing agent cinder-ceph-mysql-router 8.0.35-0ubuntu0.22.04.1 active 1 mysql-router-k8s 8.0/stable 96 10.152.183.85 no cinder-mysql 8.0.36-0ubuntu0.22.04.1 active 1 mysql-k8s 8.0/stable 153 10.152.183.166 no cinder-mysql-router 8.0.35-0ubuntu0.22.04.1 active 1 mysql-router-k8s 8.0/stable 96 10.152.183.50 no glance waiting 1 glance-k8s 2024.1/edge 103 10.152.183.105 no installing agent glance-mysql 8.0.36-0ubuntu0.22.04.1 active 1 mysql-k8s 8.0/stable 153 10.152.183.102 no glance-mysql-router 8.0.35-0ubuntu0.22.04.1 active 1 mysql-router-k8s 8.0/stable 96 10.152.183.237 no horizon waiting 1 horizon-k8s 2024.1/edge 97 10.152.183.163 no installing agent horizon-mysql 8.0.36-0ubuntu0.22.04.1 active 1 mysql-k8s 8.0/stable 153 10.152.183.254 no horizon-mysql-router 8.0.35-0ubuntu0.22.04.1 active 1 mysql-router-k8s 8.0/stable 96 10.152.183.128 no keystone waiting 1 keystone-k8s 2024.1/edge 200 10.152.183.191 no installing agent keystone-mysql 8.0.36-0ubuntu0.22.04.1 active 1 mysql-k8s 8.0/stable 153 10.152.183.26 no keystone-mysql-router 8.0.35-0ubuntu0.22.04.1 active 1 mysql-router-k8s 8.0/stable 96 10.152.183.185 no neutron waiting 1 neutron-k8s 2024.1/edge 105 10.152.183.134 no installing agent neutron-mysql 8.0.36-0ubuntu0.22.04.1 active 1 mysql-k8s 8.0/stable 153 10.152.183.108 no neutron-mysql-router 8.0.35-0ubuntu0.22.04.1 active 1 mysql-router-k8s 8.0/stable 96 10.152.183.200 no nova waiting 1 nova-k8s 2024.1/edge 95 10.152.183.241 no installing agent nova-api-mysql-router 8.0.35-0ubuntu0.22.04.1 active 1 mysql-router-k8s 8.0/stable 96 10.152.183.179 no nova-cell-mysql-router 8.0.35-0ubuntu0.22.04.1 active 1 mysql-router-k8s 8.0/stable 96 10.152.183.157 no nova-mysql 8.0.36-0ubuntu0.22.04.1 active 1 mysql-k8s 8.0/stable 153 10.152.183.103 no nova-mysql-router 8.0.35-0ubuntu0.22.04.1 active 1 mysql-router-k8s 8.0/stable 96 10.152.183.204 no ovn-central active 1 ovn-central-k8s 24.03/edge 97 10.152.183.117 no ovn-relay active 1 ovn-relay-k8s 24.03/edge 84 no placement waiting 1 placement-k8s 2024.1/edge 80 10.152.183.246 no installing agent placement-mysql 8.0.36-0ubuntu0.22.04.1 active 1 mysql-k8s 8.0/stable 153 10.152.183.151 no placement-mysql-router 8.0.35-0ubuntu0.22.04.1 active 1 mysql-router-k8s 8.0/stable 96 10.152.183.65 no rabbitmq 3.12.1 active 1 rabbitmq-k8s 3.12/stable 33 no traefik 2.10.4 waiting 1 traefik-k8s 1.0/stable 164 no installing agent traefik-public 2.10.4 waiting 1 traefik-k8s 1.0/stable 164 no installing agent traefik-rgw 2.10.4 waiting 1 traefik-k8s 1.0/stable 164 10.152.183.240 no installing agent
Unit Workload Agent Address Ports Message certificate-authority/0* active idle 10.1.206.170 cinder-ceph-mysql-router/0* active idle 10.1.206.184 cinder-ceph/0* waiting idle 10.1.206.172 (workload) Not all relations are ready cinder-mysql-router/0* active idle 10.1.206.153 cinder-mysql/0* active idle 10.1.206.136 Primary cinder/0* waiting idle 10.1.206.159 (workload) Not all relations are ready glance-mysql-router/0* active idle 10.1.206.178 glance-mysql/0* active idle 10.1.206.171 Primary glance/0* waiting idle 10.1.206.167 (ingress-internal) integration incomplete horizon-mysql-router/0* active idle 10.1.206.175 horizon-mysql/0* active idle 10.1.206.131 Primary horizon/0* waiting idle 10.1.206.180 (workload) Not all relations are ready keystone-mysql-router/0* active idle 10.1.206.161 keystone-mysql/0* active idle 10.1.206.186 Primary keystone/0* waiting idle 10.1.206.168 (workload) Not all relations are ready neutron-mysql-router/0* active idle 10.1.206.174 neutron-mysql/0* active idle 10.1.206.155 Primary neutron/0* waiting idle 10.1.206.162 (workload) Not all relations are ready nova-api-mysql-router/0* active idle 10.1.206.173 nova-cell-mysql-router/0* active idle 10.1.206.132 nova-mysql-router/0* active idle 10.1.206.177 nova-mysql/0* active idle 10.1.206.158 Primary nova/0* waiting idle 10.1.206.160 (workload) Not all relations are ready ovn-central/0* active idle 10.1.206.190 ovn-relay/0* active idle 10.1.206.129 placement-mysql-router/0* active idle 10.1.206.169 placement-mysql/0* active idle 10.1.206.154 Primary placement/0* waiting idle 10.1.206.182 (workload) Not all relations are ready rabbitmq/0* active idle 10.1.206.183 traefik-public/0* waiting idle 10.1.206.130 gateway address unavailable traefik-rgw/0* waiting idle 10.1.206.156 gateway address unavailable traefik/0* waiting idle 10.1.206.185 gateway address unavailable
Offer Application Charm Rev Connected Endpoint Interface Role cert-distributor keystone keystone-k8s 200 0/0 send-ca-cert certificate_transfer provider certificate-authority certificate-authority self-signed-certificates 155 0/0 certificates tls-certificates provider cinder-ceph cinder-ceph cinder-ceph-k8s 82 0/0 ceph-access cinder-ceph-key provider keystone-credentials keystone keystone-k8s 200 0/0 identity-credentials keystone-credentials provider keystone-endpoints keystone keystone-k8s 200 0/0 identity-service keystone provider nova nova nova-k8s 95 0/0 nova-service nova provider ovn-relay ovn-relay ovn-relay-k8s 84 0/0 ovsdb-cms-relay ovsdb-cms provider rabbitmq rabbitmq rabbitmq-k8s 33 0/0 amqp rabbitmq provider traefik-rgw traefik-rgw traefik-k8s 164 0/0 traefik-route traefik_route provider
Many thanks
