This is a template for future Release Notes affecting major releases (e.g. 2.5). Any changes to it should be updated in any WIP release notes on Discourse.
The title of the post should be Juju 2.x is the new stable series. Insert the appropriate version.
The Juju team is pleased to announce the release of Juju 2.x.
Insert version in above sentence.
Write a release summary. Include any major goals or theme and how some of the below features reflect that.
New features and major changes
Insert major change/feature
Include explanation of this feature. Provide an example if possible. Supply link to the feature’s documentation (use web docs until Discourse post is available).
Minor changes
Insert minor change
Include explanation of this change. Provide an example if possible. Supply link to the feature’s documentation (use web docs until Discourse post is available).
Insert minor change
All changes and fixes
Every change and fix to this release is tracked on a per-bug basis on Launchpad.
The most important fixes are listed below:
- [LP #
<bug number>](https://bugs.launchpad.net/juju/+bug/<bug number>) - Summary of bug - [LP #
Insert appropriate bug numbers above. Remove backticks and < > symbols.
All bugs corresponding to changes and fixes to this release are listed on the 2.x milestone page.
Insert appropriate version above.
Known issues
Explain any known issues.
Install Juju
Install Juju using the snap:
Those users already using the ‘stable’ snap channel (the default as per the above command) should be upgraded automatically. Other packages are available for a variety of platforms (see the install documentation).
Feedback Appreciated
Let us know how you’re using Juju or of any questions you may have. You can join us on Discourse, send us a message on Twitter (hashtag #jujucharms), or talk to us in the #juju IRC channel on freenode.
