Hello i have issues using Openstack deployed with MaaS/Juju .
My set-up is based on DVR (3 Compute nodes).
Each node are using one Ge interface for management/API, one DPDK bond interface (2*10Ge) and 2 (10Ge) SRIOV interfaces Data-plane.
I’m facing 2 issues :
- Cloudinit
- Overlay with selfservice network
For the 1st issue, only config-drive works. No responses from Metadata services either from the VM or from the Compute namespace when using cloud-init images (both for self-services or provider networks).
For 2nd issue, only self-service instances spawned on the same compute where the DHCP service resides will have connectivity. Traffic over VXLAN don’t seems to pass between instances on other compute nodes and the compute node where the dhcp service is located.
No network connectivity or MTU issue between Compute Nodes on the Overlay VLAN.
By the way instances on provider networks work fine whatever the compute node is.
Any help or guidance will be appreciated for both issues.
Thanks.
I’m using the following bundle:
xxx:~$ more Juju/openstack-base-65/bundle-dvr-ha-mem.yaml
variables:
openstack-origin: &openstack-origin cloud:bionic-train
worker-multiplier: &worker-multiplier 0.25
osd-devices: &osd-devices /dev/vdb /dev/vdc /dev/sda /dev/sdb /dev/sdc /dev/sdd /dev/sde /dev/sdf /dev/sdg /dev/sdh
vlan-ranges: &vlan-ranges prov_dpdk:200:300 prov_sriov_1:200:300 prov_sriov_2:200:300
expected-osd-count: &expected-osd-count 3
expected-mon-count: &expected-mon-count 3
machines:
"0":
series: bionic
constraints: tags=virtual,ctrl zones=DC1-AZ2
'1':
series: bionic
constraints: tags=compute,dual-core-ht-off,hdd zones=DC1-AZ1
'2':
series: bionic
constraints: tags=virtual,ctrl zones=DC1-AZ3
'3':
series: bionic
constraints: tags=compute,single-core,hdd zones=DC1-AZ2
'4':
series: bionic
constraints: tags=network,single-core,hdd zones=DC1-AZ3
'5':
series: bionic
relations:
- - nova-compute:amqp
- rabbitmq-server:amqp
- - keystone:shared-db
- mysql:shared-db
- - nova-cloud-controller:identity-service
- keystone:identity-service
- - glance:identity-service
- - neutron-api:identity-service
- - neutron-openvswitch:neutron-plugin-api
- neutron-api:neutron-plugin-api
- - neutron-api:shared-db
- mysql:shared-db
- - neutron-api:amqp
- - glance:shared-db
- mysql:shared-db
- - glance:amqp
- - nova-cloud-controller:image-service
- glance:image-service
- - nova-compute:image-service
- - nova-cloud-controller:cloud-compute
- nova-compute:cloud-compute
- - nova-cloud-controller:amqp
- - nova-compute:neutron-plugin
- - neutron-openvswitch:amqp
- - openstack-dashboard:identity-service
- - nova-cloud-controller:shared-db
- mysql:shared-db
- - nova-cloud-controller:neutron-api
- neutron-api:neutron-api
- - cinder:image-service
- - cinder:amqp
- - cinder:identity-service
- - cinder:cinder-volume-service
- nova-cloud-controller:cinder-volume-service
- - cinder-ceph:storage-backend
- cinder:storage-backend
- - ceph-mon:client
- nova-compute:ceph
- - nova-compute:ceph-access
- cinder-ceph:ceph-access
- - cinder:shared-db
- mysql:shared-db
- - ceph-mon:client
- cinder-ceph:ceph
- - ceph-mon:client
- glance:ceph
- - ceph-osd:mon
- ceph-mon:osd
- - ntp:juju-info
- nova-compute:juju-info
- - ceph-radosgw:mon
- ceph-mon:radosgw
- - ceph-radosgw:identity-service
- - placement
- mysql
- - placement
- keystone
- - placement
- - nova-cloud-controller:memcache
- memcached:cache
series: bionic
services:
ceph-mon:
bindings:
public: storage-data
cluster: storage-cluster
annotations:
gui-x: '750'
gui-y: '500'
charm: cs:ceph-mon-44
num_units: 3
options:
expected-osd-count: *expected-osd-count
monitor-count: *expected-mon-count
source: *openstack-origin
to:
- lxd:1
- lxd:3
- lxd:4
ceph-osd:
bindings:
annotations:
gui-x: '1000'
gui-y: '500'
charm: cs:ceph-osd-294
num_units: 3
#num_units: 4
options:
osd-devices: *osd-devices
to:
- '1'
- '3'
- '4'
ceph-radosgw:
bindings:
public: public-api
internal: internal-api
admin: admin-api
annotations:
gui-x: '1000'
gui-y: '250'
charm: cs:ceph-radosgw-283
num_units: 1
options:
to:
- lxd:0
cinder:
bindings:
public: public-api
admin: admin-api
shared-db: internal-api
annotations:
gui-x: '750'
gui-y: '0'
charm: cs:cinder-297
num_units: 1
options:
block-device: None
glance-api-version: 2
openstack-origin: *openstack-origin
worker-multiplier: *worker-multiplier
to:
- 0
cinder-ceph:
annotations:
gui-x: '750'
gui-y: '250'
charm: cs:cinder-ceph-251
num_units: 0
options:
ceph-osd-replication-count: 3
glance:
bindings:
public: public-api
admin: admin-api
annotations:
gui-x: '250'
gui-y: '0'
charm: cs:glance-291
num_units: 1
options:
to:
- 5
keystone:
bindings:
public: public-api
admin: admin-api
annotations:
gui-x: '500'
gui-y: '0'
charm: cs:keystone-309
num_units: 1
options:
to:
- lxd:2
mysql:
bindings:
annotations:
gui-x: '0'
gui-y: '250'
charm: cs:percona-cluster-281
num_units: 1
options:
innodb-buffer-pool-size: 256M
max-connections: 1000
performance-schema: true
to:
- lxd:5
neutron-api:
bindings:
public: public-api
admin: admin-api
annotations:
gui-x: '500'
gui-y: '500'
charm: cs:neutron-api-282
num_units: 1
options:
flat-network-providers: prov_dpdk prov_sriov_1 prov_sriov_2
global-physnet-mtu: 9000
neutron-security-groups: true
overlay-network-type: vxlan
enable-dvr: true
enable-l3ha: true
max-l3-agents-per-router : 2
enable-sriov: true
vlan-ranges: *vlan-ranges
to:
- lxd:4
bindings:
data: compute-data
annotations:
gui-x: '250'
gui-y: '500'
charm: cs:neutron-openvswitch-269
num_units: 0
options:
bridge-mappings: prov_dpdk:br-data
data-port: br-data:bond-dpdk
use-dvr-snat: true
enable-local-dhcp-and-metadata: true
enable-dpdk: true
dpdk-socket-cores: 1
dpdk-socket-memory: 1024
dpdk-driver: vfio-pci
dpdk-bond-mappings: "bond-dpdk:e4:43:4b:b6:f5:dc bond-dpdk:f8:f2:1e:82:2a:80 bond-dpdk:e4:43:4b:ab:65:76 bond-dpdk:f8:f2:1e:82:31:80 bond-dpdk:e4:43:4b:b6:7e:ba bond-dpdk:f8:f2:1e:82:
31:70 bond-dpdk:e4:43:4b:ab:27:74 bond-dpdk:f8:f2:1e:82:32:30"
dpdk-bond-config: ":balance-tcp:active:fast"
enable-sriov: true
sriov-device-mappings: "prov_sriov_1:eno2 prov_sriov_2:enp179s0f1 prov_sriov_2:enp94s0f1"
sriov-numvfs: "eno2:16 enp179s0f1:16 enp94s0f1:16"
bindings:
public: public-api
admin: admin-api
annotations:
gui-x: '0'
gui-y: '500'
charm: cs:nova-cloud-controller-339
num_units: 1
options:
network-manager: Neutron
console-access-protocol: vnc
to:
- 2
nova-compute:
annotations:
gui-x: '250'
gui-y: '250'
charm: cs:nova-compute-309
num_units: 3
options:
config-flags: default_ephemeral_format=ext4
enable-live-migration: true
enable-resize: true
migration-auth-type: ssh
cpu-mode: host-passthrough
reserved-host-memory: 2048
pci-passthrough-whitelist: '[{"devname":"eno2", "physical_network":"prov_sriov_1"},{"devname":"enp94s0f1","physical_network":"prov_sriov_2"},{"devname":"enp179s0f1", "physical_network
":"prov_sriov_2"},{"address":"*:17:00.01", "physical_network":"prov_sriov_1"},{"address":"*:18:00.01", "physical_network":"prov_sriov_1"},{"address":"*:b3:00.01", "physical_network":"prov_s
riov_2"},{"address":"*:5e:00.01", "physical_network":"prov_sriov_2"}]'
to:
- '1'
- '3'
- '4'
ntp:
annotations:
gui-x: '1000'
gui-y: '0'
charm: cs:ntp-36
num_units: 0
bindings:
public: public-api
annotations:
gui-x: '500'
gui-y: '-250'
charm: cs:openstack-dashboard-297
num_units: 1
options:
to:
- lxd:0
placement:
bindings:
public: public-api
admin: admin-api
annotations:
gui-x: '0'
gui-y: '500'
charm: cs:~openstack-charmers/bionic/placement
num_units: 1
options:
to:
- lxd:5
rabbitmq-server:
bindings:
amqp: internal-api
annotations:
gui-x: '500'
gui-y: '250'
charm: cs:rabbitmq-server-97
num_units: 1
to:
- lxd:3
memcached:
bindings:
"": internal-api
charm: cs:memcached
num_units: 1
to:
- lxd:2
Juju status:
xxx:~$ juju status
default maas-ctrl-dc1 maas-tdf/default 2.7.6 unsupported 10:35:43+02:00
ceph-mon 14.2.11 active 3 ceph-mon jujucharms 44 ubuntu
ceph-osd 14.2.11 active 3 ceph-osd jujucharms 294 ubuntu
ceph-radosgw 14.2.11 active 1 ceph-radosgw jujucharms 283 ubuntu
cinder 15.3.0 active 1 cinder jujucharms 297 ubuntu
cinder-ceph 15.3.0 active 1 cinder-ceph jujucharms 251 ubuntu
glance 19.0.4 active 1 glance jujucharms 291 ubuntu
keystone 16.0.1 active 1 keystone jujucharms 309 ubuntu
memcached active 1 memcached jujucharms 30 ubuntu
mysql 5.7.20 active 1 percona-cluster jujucharms 281 ubuntu
neutron-api 15.1.0 active 1 neutron-api jujucharms 282 ubuntu
neutron-openvswitch 15.1.0 active 3 neutron-openvswitch jujucharms 269 ubuntu
nova-cloud-controller 20.3.0 active 1 nova-cloud-controller jujucharms 339 ubuntu
nova-compute 20.3.0 active 3 nova-compute jujucharms 309 ubuntu
ntp 3.2 active 3 ntp jujucharms 36 ubuntu
openstack-dashboard 16.2.0 active 1 openstack-dashboard jujucharms 297 ubuntu
placement 2.0.0 active 1 placement jujucharms 15 ubuntu
rabbitmq-server 3.6.10 active 1 rabbitmq-server jujucharms 97 ubuntu
ceph-mon/0* active idle 1/lxd/0 10.40.0.210 Unit is ready and clustered
ceph-mon/1 active idle 3/lxd/0 10.40.0.207 Unit is ready and clustered
ceph-mon/2 active idle 4/lxd/0 10.40.0.203 Unit is ready and clustered
ceph-osd/0 active idle 1 10.10.0.204 Unit is ready (8 OSD)
ceph-osd/1 active idle 3 10.10.0.205 Unit is ready (4 OSD)
ceph-osd/2* active idle 4 10.10.0.206 Unit is ready (4 OSD)
ceph-radosgw/0* active idle 0/lxd/0 10.10.0.209 80/tcp Unit is ready
cinder/0* active idle 0 10.10.0.212 8776/tcp Unit is ready
cinder-ceph/0* active idle 10.10.0.212 Unit is ready
glance/0* active idle 5 10.10.0.214 9292/tcp Unit is ready
keystone/0* active idle 2/lxd/0 10.10.0.243 5000/tcp Unit is ready
memcached/0* active idle 2/lxd/1 10.20.0.219 11211/tcp Unit is ready
mysql/0* active idle 5/lxd/0 10.20.0.218 3306/tcp Unit is ready
neutron-api/0* active idle 4/lxd/1 10.10.0.242 9696/tcp Unit is ready
nova-cloud-controller/0* active idle 2 10.10.0.213 8774/tcp,8775/tcp Unit is ready
nova-compute/0 active idle 1 10.10.0.204 Unit is ready
neutron-openvswitch/0* active idle 10.10.0.204 Unit is ready
ntp/0* active idle 10.10.0.204 123/udp chrony: Ready
nova-compute/1 active idle 3 10.10.0.205 Unit is ready
neutron-openvswitch/2 active idle 10.10.0.205 Unit is ready
ntp/1 active idle 10.10.0.205 123/udp chrony: Ready
nova-compute/2* active idle 4 10.10.0.206 Unit is ready
neutron-openvswitch/1 active idle 10.10.0.206 Unit is ready
ntp/2 active idle 10.10.0.206 123/udp chrony: Ready
openstack-dashboard/0* active idle 0/lxd/1 10.30.0.209 80/tcp,443/tcp Unit is ready
placement/0* active idle 5/lxd/1 10.10.0.252 8778/tcp Unit is ready
rabbitmq-server/0* active idle 3/lxd/1 10.20.0.221 5672/tcp Unit is ready
0 started 10.10.0.212 cp1-2 bionic DC1-AZ2 Deployed
0/lxd/0 started 10.10.0.209 juju-2a779e-0-lxd-0 bionic DC1-AZ2 Container started
0/lxd/1 started 10.30.0.209 juju-2a779e-0-lxd-1 bionic DC1-AZ2 Container started
1 started 10.10.0.204 copernic bionic DC1-AZ1 Deployed
1/lxd/0 started 10.40.0.210 juju-2a779e-1-lxd-0 bionic DC1-AZ1 Container started
2 started 10.10.0.213 cp1-3 bionic DC1-AZ3 Deployed
2/lxd/0 started 10.10.0.243 juju-2a779e-2-lxd-0 bionic DC1-AZ3 Container started
2/lxd/1 started 10.20.0.219 juju-2a779e-2-lxd-1 bionic DC1-AZ3 Container started
3 started 10.10.0.205 sirius bionic DC1-AZ2 Deployed
3/lxd/0 started 10.40.0.207 juju-2a779e-3-lxd-0 bionic DC1-AZ2 Container started
3/lxd/1 started 10.20.0.221 juju-2a779e-3-lxd-1 bionic DC1-AZ2 Container started
4 started 10.10.0.206 polaris bionic DC1-AZ3 Deployed
4/lxd/0 started 10.40.0.203 juju-2a779e-4-lxd-0 bionic DC1-AZ3 Container started
4/lxd/1 started 10.10.0.242 juju-2a779e-4-lxd-1 bionic DC1-AZ3 Container started
5 started 10.10.0.214 cp1-4 bionic DC1-AZ3 Deployed
5/lxd/0 started 10.20.0.218 juju-2a779e-5-lxd-0 bionic DC1-AZ3 Container started
5/lxd/1 started 10.10.0.252 juju-2a779e-5-lxd-1 bionic DC1-AZ3 Container started
–>Nova services
xxx:~$ openstack compute service list
| ID | Binary | Host | Zone | Status | State | Updated At |
| 1 | nova-conductor | cp1-3 | internal | enabled | up | 2020-10-05T10:30:55.000000 |
| 2 | nova-scheduler | cp1-3 | internal | enabled | up | 2020-10-05T10:30:47.000000 |
| 4 | nova-compute | eno4.10.polaris.maas | nfv2 | enabled | up | 2020-10-05T10:30:55.000000 |
| 6 | nova-compute | eno4.10.copernic.maas | nfv1 | enabled | up | 2020-10-05T10:30:55.000000 |
| 7 | nova-compute | eno4.10.sirius.maas | nfv2 | enabled | up | 2020-10-05T10:30:55.000000 |
xxx:~$ openstack host list
| Host Name | Service | Zone |
| cp1-3 | conductor | internal |
| cp1-3 | scheduler | internal |
| eno4.10.polaris.maas | compute | nfv2 |
| eno4.10.copernic.maas | compute | nfv1 |
| eno4.10.sirius.maas | compute | nfv2 |
xxx:~$ openstack hypervisor list
| ID | Hypervisor Hostname | Hypervisor Type | Host IP | State |
| 1 | polaris.maas | QEMU | 10.10.0.206 | up |
| 2 | copernic.maas | QEMU | 10.10.0.204 | up |
| 3 | sirius.maas | QEMU | 10.10.0.205 | up |
xxx:~$ openstack network list --long
| ID | Name | Status | Project | State | Shared | Subnets | Network Type | Router Type | Availability Zones | Tags |
| 0141d8e6-4afe-4654-b310-5122b09425da | ext_net_10.200 | ACTIVE | 0abf6175646545ec97732059317d3d31 | UP | True | 5c8b9870-72a3-4b6b-b4d7-0b2406f21520 | None | External | nova | |
| 18faf4d6-ed38-4bca-8be7-b2ac162da789 | int_net_172.16 | ACTIVE | 7ab86a607037437488805b599bec396c | UP | False | f5c65fc6-7365-452a-b1d4-9eefb3aad4aa | None | Internal | nova | |
| 69700bed-fa39-4c55-bf8c-e8d003db7314 | int_net_10.220 | ACTIVE | 0abf6175646545ec97732059317d3d31 | UP | True | 3bb33507-dbc5-480c-b400-fd87103a576a | None | Internal | nova | |
| b47b7d33-4349-4e6d-b452-2cfe51e2087c | int_net_10.210 | ACTIVE | 0abf6175646545ec97732059317d3d31 | UP | True | f378fe16-fd98-4975-ae03-5c395be9601e | None | Internal | nova | |
| bdeef42f-30d1-40db-8977-7141d5dc7e3c | int_net_10.220 | ACTIVE | 0abf6175646545ec97732059317d3d31 | UP | True | 93f7dd98-0796-4aef-ac4d-9abb85504d05 | None | Internal | nova | |
| ID | Name | Subnets |
| 0141d8e6-4afe-4654-b310-5122b09425da | ext_net_10.200 | 5c8b9870-72a3-4b6b-b4d7-0b2406f21520 |
| 18faf4d6-ed38-4bca-8be7-b2ac162da789 | int_net_172.16 | f5c65fc6-7365-452a-b1d4-9eefb3aad4aa |
| 69700bed-fa39-4c55-bf8c-e8d003db7314 | int_net_10.220 | 3bb33507-dbc5-480c-b400-fd87103a576a |
| 764c6d0b-0f52-4622-89f9-4712890db30e | HA network tenant 7ab86a607037437488805b599bec396c | 87d190da-ee90-4ffa-a667-4b0291032880 |
| b47b7d33-4349-4e6d-b452-2cfe51e2087c | int_net_10.210 | f378fe16-fd98-4975-ae03-5c395be9601e |
| bdeef42f-30d1-40db-8977-7141d5dc7e3c | int_net_10.220 | 93f7dd98-0796-4aef-ac4d-9abb85504d05 |
xxx:~$ openstack network segment list
| ID | Name | Network | Network Type | Segment |
| 18bd7b1a-c5fd-4aac-87a7-40953aab3628 | None | 0141d8e6-4afe-4654-b310-5122b09425da | vlan | 200 |
| 4076e1bd-ea85-4643-a529-0850d80a4322 | None | b47b7d33-4349-4e6d-b452-2cfe51e2087c | vlan | 210 |
| 63a4cd92-ebbc-4869-a2f4-053bd85983cd | None | bdeef42f-30d1-40db-8977-7141d5dc7e3c | vlan | 220 |
| 8cf09acb-6670-4df9-bb4a-e3ba2c6d079d | None | 18faf4d6-ed38-4bca-8be7-b2ac162da789 | vxlan | 1001 |
| 92534297-1df8-4322-853d-f3d15a57c57d | None | 69700bed-fa39-4c55-bf8c-e8d003db7314 | vlan | 220 |
| ad5a7259-4e72-4305-a378-c73a0f62d8ad | None | 764c6d0b-0f52-4622-89f9-4712890db30e | vxlan | 1002 |
–>Compute/0
xxx:~$ juju ssh nova-compute/0
ubuntu@copernic:~$ ip ro
default via 10.14.0.254 dev eno3 proto static
10.10.0.0/24 dev eno4.10 proto kernel scope link src 10.10.0.204
10.14.0.0/24 dev eno3 proto kernel scope link src 10.14.0.204
10.20.0.0/24 dev eno4.20 proto kernel scope link src 10.20.0.204
10.30.0.0/24 dev eno4.30 proto kernel scope link src 10.30.0.204
10.40.0.0/24 dev br-eno4-40 proto kernel scope link src 10.40.0.204
10.50.0.0/24 dev br-eno4-50 proto kernel scope link src 10.50.0.204
10.100.0.0/24 dev vif100 proto kernel scope link src 10.100.0.204
10.200.0.0/24 dev vif200 proto kernel scope link src 10.200.0.204
10.206.182.0/24 dev lxdbr0 proto kernel scope link src 10.206.182.1
10.210.0.0/24 dev vif210 proto kernel scope link src 10.210.0.204
10.220.0.0/24 dev vif220 proto kernel scope link src 10.220.0.204
ubuntu@copernic:~$ sudo ovs-vsctl show
00eebfb8-68c0-4c03-8573-732e3f9f2561
Manager "ptcp:6640:127.0.0.1"
is_connected: true
Bridge br-data
Controller "tcp:127.0.0.1:6633"
is_connected: true
fail_mode: secure
datapath_type: netdev
Port br-data
Interface br-data
type: internal
Port "vif200"
tag: 200
Interface "vif200"
type: internal
Port "vif220"
tag: 220
Interface "vif220"
type: internal
Port "vif100"
tag: 100
Interface "vif100"
type: internal
Port phy-br-data
Interface phy-br-data
type: patch
options: {peer=int-br-data}
Port bond-dpdk
Interface "dpdk-5fe3176"
type: dpdk
options: {dpdk-devargs="0000:18:00.0"}
Interface "dpdk-0ce9eee"
type: dpdk
options: {dpdk-devargs="0000:5e:00.0"}
Port "vif210"
tag: 210
Interface "vif210"
type: internal
Bridge br-ex
Port br-ex
Interface br-ex
type: internal
Bridge br-int
is_connected: true
fail_mode: secure
Port "fg-c15ebf73-12"
tag: 3
Interface "fg-c15ebf73-12"
type: internal
Port "qr-ba93feeb-ed"
tag: 1
Interface "qr-ba93feeb-ed"
type: internal
Port "vhuafd9edf6-7f"
tag: 4
Interface "vhuafd9edf6-7f"
type: dpdkvhostuserclient
options: {vhost-server-path="/run/libvirt-vhost-user/vhuafd9edf6-7f"}
Port "qg-663a571a-e0"
tag: 3
Interface "qg-663a571a-e0"
type: internal
Port "ha-fd964971-93"
tag: 2
Interface "ha-fd964971-93"
type: internal
Port "vhu6694bae2-57"
tag: 4
Interface "vhu6694bae2-57"
options: {vhost-server-path="/run/libvirt-vhost-user/vhu6694bae2-57"}
Port br-int
Interface br-int
type: internal
Port "vhu1ce6fe1d-df"
tag: 1
Interface "vhu1ce6fe1d-df"
options: {vhost-server-path="/run/libvirt-vhost-user/vhu1ce6fe1d-df"}
Port "tap190d775e-0a"
tag: 1
Interface "tap190d775e-0a"
Port int-br-data
Interface int-br-data
type: patch
options: {peer=phy-br-data}
Port "vhu650e5335-0a"
tag: 4
Interface "vhu650e5335-0a"
options: {vhost-server-path="/run/libvirt-vhost-user/vhu650e5335-0a"}
Port "sg-2f7665c6-2f"
tag: 1
Interface "sg-2f7665c6-2f"
type: internal
Port patch-tun
Interface patch-tun
type: patch
options: {peer=patch-int}
Bridge br-tun
is_connected: true
fail_mode: secure
Port patch-int
Interface patch-int
type: patch
options: {peer=patch-tun}
Port "vxlan-0a6400ce"
Interface "vxlan-0a6400ce"
type: vxlan
options: {df_default="true", egress_pkt_mark="0", in_key=flow, local_ip="10.100.0.204", out_key=flow, remote_ip="10.100.0.206"}
Port "vxlan-0a6400cd"
Interface "vxlan-0a6400cd"
type: vxlan
options: {df_default="true", egress_pkt_mark="0", in_key=flow, local_ip="10.100.0.204", out_key=flow, remote_ip="10.100.0.205"}
Port br-tun
Interface br-tun
type: internal
ovs_version: "2.12.0"
ubuntu@copernic:~$ ip netns
fip-0141d8e6-4afe-4654-b310-5122b09425da (id: 4)
qrouter-122a9c91-6b53-4453-869e-be3faaf312f5 (id: 3)
snat-122a9c91-6b53-4453-869e-be3faaf312f5 (id: 2)
qdhcp-18faf4d6-ed38-4bca-8be7-b2ac162da789 (id: 1) *-->self-service dhcp namespace*
ubuntu@copernic:~$ sudo ip netns exec qdhcp-18faf4d6-ed38-4bca-8be7-b2ac162da789 ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: ns-190d775e-0a@if65: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 8950 qdisc noqueue state UP group default qlen 1000
link/ether fa:16:3e:f0:0a:3d brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 169.254.169.254/16 brd 169.254.255.255 scope global ns-190d775e-0a
inet 172.16.0.10/24 brd 172.16.0.255 scope global ns-190d775e-0a
inet6 fe80::f816:3eff:fef0:a3d/64 scope link
Ping compute/1 on vlan 100 (for vxlan overlay)
ubuntu@copernic:~$ ping -M do -s 8972 10.100.0.205 -I vif100
PING 10.100.0.205 (10.100.0.205) from 10.100.0.204 vif100: 8972(9000) bytes of data.
8980 bytes from 10.100.0.205: icmp_seq=1 ttl=63 time=0.668 ms
8980 bytes from 10.100.0.205: icmp_seq=2 ttl=63 time=0.440 ms
–>Instances (vm-ubuntu-ci-3 is on compute/0(dhcp service), vm-ubuntu-ci-4 on compute/1.
xxx:~$ openstack server list
| ID | Name | Status | Networks | Image | Flavor |
| c42ecf9b-56bc-4489-a443-0964aefd6c46 | vm-ubuntu-ci-4 | ACTIVE | int_net_172.16=172.16.0.19, 10.200.0.191 | ubuntu_bionic_18_04 | s.nvf2 |
| c80f714c-3ca3-4785-94f7-12171f80293c | vm-ubuntu-ci-3 | ACTIVE | int_net_172.16=172.16.0.15, 10.200.0.107 | ubuntu_bionic_18_04 | s.nvf1 |
xxx:~$ ping 10.200.0.107
PING 10.200.0.107 (10.200.0.107) 56(84) bytes of data.
64 bytes from 10.200.0.107: icmp_seq=1 ttl=62 time=476 ms
64 bytes from 10.200.0.107: icmp_seq=2 ttl=62 time=0.374 ms
64 bytes from 10.200.0.107: icmp_seq=3 ttl=62 time=0.375 ms
^C
--- 10.200.0.107 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2023ms
rtt min/avg/max/mdev = 0.374/158.922/476.017/224.220 ms
admintdf@omega:~$ ping 10.200.0.191
PING 10.200.0.191 (10.200.0.191) 56(84) bytes of data.
^C
--- 10.200.0.191 ping statistics ---
6 packets transmitted, 0 received, 100% packet loss, time 5124ms
