Tactic Troubles
Hello,
Just wrote my first tactic and I’m experiencing an issue. The issue is that I cannot build my charm without including the wheelhouse tactic in my charm.
Running make build in my layer shows (layer.yaml)
bdx@devdev:~/allcode/charms/layers/layer-elastic-operator$ make build
rm -rf .tox/
rm -rf build/
rm -rf charm-store-push-result.txt
tox -e build
build create: /home/bdx/allcode/charms/layers/layer-elastic-operator/.tox/build
build installdeps: -r/home/bdx/allcode/charms/layers/layer-elastic-operator/test-requirements.txt
build installed: atomicwrites==1.3.0,attrs==19.2.0,entrypoints==0.3,filelock==3.0.12,flake8==3.7.8,importlib-metadata==0.23,mccabe==0.6.1,more-itertools==7.2.0,packaging==19.2,pep8==1.7.1,pkg-resources==0.0.0,pluggy==0.13.0,py==1.8.0,pycodestyle==2.5.0,pyflakes==2.1.1,pyparsing==2.4.2,pytest==5.2.0,six==1.12.0,toml==0.10.0,tox==3.14.0,virtualenv==16.7.5,wcwidth==0.1.7,yapf==0.28.0,zipp==0.6.0
build runtests: PYTHONHASHSEED='0'
build runtests: commands[0] | sh -c snap list charm 2>/dev/null || sudo snap install charm --classic
Name   Version  Rev  Tracking  Publisher  Notes
charm  2.7.1    390  stable    johnsca    classic
build runtests: commands[1] | charm build --log-level DEBUG -o /home/bdx/allcode/charms/layers/layer-elastic-operator/build src
build: {
  "CHARM_BUILD_DIR": null,
  "CHARM_INTERFACES_DIR": "/home/bdx/allcode/charms/layers/layer-elastic-operator/interfaces",
  "CHARM_LAYERS_DIR": "/home/bdx/allcode/charms/layers/layer-elastic-operator/layers",
  "INTERFACE_PATH": null,
  "JUJU_REPOSITORY": "/home/bdx/allcode/charms/layers/layer-elastic-operator/build",
  "LAYER_PATH": null,
  "_charm": "src",
  "_charm_metadata": {
    "description": "Elastic.co K8S operator.\n",
    "display-name": "elastic-operator",
    "maintainers": [
      "Omnivector Solutions <admin@omnivector.solutions>"
    "name": "elastic-operator",
    "resources": {
      "elastic_operator_image": {
        "description": "Elastic operator image.",
        "type": "oci-image"
    "series": [
      "kubernetes"
    "storage": {
      "cert": {
        "location": "/tmp/cert",
        "type": "filesystem"
    "summary": "Elastic Operator",
    "tags": [
      "elastic",
      "elastic.co"
  "_name": null,
  "_top_layer": null,
  "_warned_home": false,
  "build_dir": "/home/bdx/allcode/charms/layers/layer-elastic-operator/build/builds",
  "cache_dir": "/home/bdx/.cache/charm/27022",
  "config": "BuildConfig({'_tactics': [], 'configured': False})",
  "debug": false,
  "description": false,
  "force": false,
  "force_color": false,
  "hide_metrics": false,
  "interface_service": null,
  "layer_index": null,
  "log_level": "DEBUG",
  "no_local_layers": false,
  "output_dir": "/home/bdx/allcode/charms/layers/layer-elastic-operator/build",
  "report": false,
  "series": null,
  "verbose": false,
  "wheelhouse_overrides": null
charmtools.fetchers: git rev-parse HEAD: b'4ddd74e05e0eff93ffaa7a4763a91b2b09a860ea\n'
build: Destination charm directory: /home/bdx/allcode/charms/layers/layer-elastic-operator/build/builds/elastic-operator
charmtools.build.fetchers: Checking layer index: https://juju.github.io/layer-index/layers/caas-base.json
charmtools.build.fetchers: Found repo: https://github.com/juju-solutions/layer-caas-base.git
charmtools.fetchers: git clone https://github.com/juju-solutions/layer-caas-base.git /home/bdx/.cache/charm/27022/layer/tmps9oqkmm6: b"Cloning into '/home/bdx/.cache/charm/27022/layer/tmps9oqkmm6'...\nwarning: templates not found /snap/charm/390/share/git-core/templates\n"
charmtools.fetchers: git rev-parse HEAD: b'fac96d3e2cc3b67fd450985800377643e8e13c73\n'
charmtools.build.fetchers: Copying /home/bdx/.cache/charm/27022/layer/tmps9oqkmm6 to /home/bdx/.cache/charm/27022/layer/caas-base
charmtools.build.fetchers: Cleaning up /home/bdx/.cache/charm/27022/layer/tmps9oqkmm6
  File "/snap/charm/390/bin/charm-build", line 11, in <module>
    load_entry_point('charm-tools==2.7.1', 'console_scripts', 'charm-build')()
  File "/snap/charm/390/lib/python3.6/site-packages/charmtools/build/builder.py", line 941, in main
    build()
  File "/snap/charm/390/lib/python3.6/site-packages/charmtools/build/builder.py", line 649, in __call__
    self.generate()
  File "/snap/charm/390/lib/python3.6/site-packages/charmtools/build/builder.py", line 592, in generate
    layers = self.fetch()
  File "/snap/charm/390/lib/python3.6/site-packages/charmtools/build/builder.py", line 273, in fetch
    return self.fetch_deps(self.top_layer)
  File "/snap/charm/390/lib/python3.6/site-packages/charmtools/build/builder.py", line 278, in fetch_deps
    self.fetch_dep(layer, results)
  File "/snap/charm/390/lib/python3.6/site-packages/charmtools/build/builder.py", line 313, in fetch_dep
    base_layer.fetch()
  File "/snap/charm/390/lib/python3.6/site-packages/charmtools/build/builder.py", line 114, in fetch
    self._name = self.config.name
  File "/snap/charm/390/lib/python3.6/site-packages/charmtools/build/builder.py", line 51, in config
    self._config.configure(self.config_file)
  File "/snap/charm/390/lib/python3.6/site-packages/charmtools/build/config.py", line 66, in configure
    tactic = load_tactic(name, basedir)
  File "/snap/charm/390/lib/python3.6/site-packages/charmtools/build/tactics.py", line 1282, in load_tactic
    obj = utils.load_class(dpath, basedir)
  File "/snap/charm/390/lib/python3.6/site-packages/charmtools/utils.py", line 333, in load_class
    module = importlib.import_module(module_path)
  File "/snap/charm/390/usr/lib/python3.6/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 994, in _gcd_import
  File "<frozen importlib._bootstrap>", line 971, in _find_and_load
  File "<frozen importlib._bootstrap>", line 953, in _find_and_load_unlocked
ModuleNotFoundError: No module named 'tactics.wheelhouse'
ERROR: InvocationError: '/snap/bin/charm build --log-level DEBUG -o /home/bdx/allcode/charms/layers/layer-elastic-operator/build src'
__________________________________________________________ summary __________________________________________________________
ERROR:   build: commands failed
Makefile:20: recipe for target 'build' failed
make: *** [build] Error 1
Adding the wheelhouse.py tactic to my tactics/ and to my layer.yaml allows the charm to build.
any ideas here?
Thanks
Filed bug
Cross-posting from the bug for visibility:
The caas-base layer includes a custom WheelhouseTactic to override the default one built into charm build to account for the fact that k8s charms cannot perform the normal bootstrap and installation, so instead of bundling packaged wheel or egg files, it has to essentially create an embedded virtualenv. However, both the tactics/ directory and the tactics: [] list in layer.yaml should be merged without you having to re-specify and include that custom tactic.
That the merging isn’t happening as it should is a bug with charm build.
