How to horizontally scale
A Synapse deployment can scale horizontally by running multiple Synapse processes called workers. While adding more units to the Synapse charm, one of them will be the Main process and others, the workers. This architecture has specific requirements that will be described in this document.
For more details about scaling, refer to “Scaling synapse via workers” in the Synapse documentation.
Requirements
- Synapse charm deployed and integrated with PostgreSQL charm.
The tutorial “Getting started” can be used to meet this requirement.
Steps
Deploy Redis and integrate it with Synapse
Run the following commands.
juju deploy redis-k8s --channel edge
juju integrate synapse redis
Once the output of the juju status command shows that the units are active and idle, proceed with
the next step.
Deploy S3-integrator and integrate it with Synapse
This will enable S3 storage provider so media will be stored on a S3 bucket.
Replace the configuration options with your specific configuration. The ones used below should be modified to match your environment.
Refer to s3-integrator for specific configuration options.
juju deploy s3-integrator s3-integrator-media --channel edge
juju config s3-integrator-media endpoint=http://endpoint bucket=synapse-media-bucket path=/media region=us-east-1 s3-uri-style=path
juju integrate synapse:media s3-integrator-media
the next step.
Scale Synapse application
With all integrations set, scale Synapse up by running the following command.
juju scale-application synapse 3
Verify status
The output of juju status --relations should look like this now.
$ juju status --relations
prod-synapse-k8s ctr1 cloud1/default 3.1.8 unsupported 20:04:20Z
SAAS Status Store URL
postgresql active cloud1 admin/prod-chat-synapse-db.postgresql
media-s3-integrator active 1 s3-integrator latest/stable 13 10.10.10.1 no
redis 7.0.4 active 1 redis-k8s latest/edge 27 10.10.10.2 no
synapse active 3 synapse latest/stable 303 10.10.10.3 no
media-s3-integrator/0* active idle 192.168.1.2
redis/0* active idle 192.168.1.7
synapse/0 active idle 192.168.1.4
synapse/1* active idle 192.168.1.8
synapse/2 active idle 192.168.1.6
media-s3-integrator:s3-credentials synapse:media s3 regular
media-s3-integrator:s3-integrator-peers media-s3-integrator:s3-integrator-peers s3-integrator-peers peer
postgresql:database synapse:database postgresql_client regular
redis:redis synapse:redis redis regular
redis:redis-peers redis:redis-peers redis-peers peer
synapse:synapse-peers synapse:synapse-peers synapse-instance peer
