Hi folks,
I’m not sure where to suggest this so doing it here.
In the charm page (any charm) on charmhub there’s no search bar. So in order to search for a different charm, the user have to click on Charmhub on the top section to go back to the website home for then search something else.
I suggest we add an always visible search button on the header to facilitate browsing. Here’s an example of this forum header containing a search button that could be used as a guide, note that they’re quite similar:
Thanks for you time and let me know if there’s a better place to suggest this.
