Configure iSCSI
Set the storage-type to “iscsi” and configure the target and port.
juju config storage-connector \
storage-type='iscsi' \
iscsi-target=<TARGET_IP> \
iscsi-port=<PORT>
The iSCSI initiator name can be configured through the initiator-dictionary config option. This modifies the /etc/iscsi/initiatorname.iscsi file and allows you to specify the node’s initiator name (which will be generated randomly otherwise).
initiator-dictionary='{"hostname1": "iqn.yyyy-mm.naming-authority:uniquename1", "hostname2": "iqn.yyyy-mm.naming-authority:uniquename2"}'
The restarting of the services after iSCSI related changes does not happen automatically. Read more about the reasoning behind this here.
Restart the iSCSI services through the restart-services charm action.
juju run storage-connector/0 restart-services --params services="iscsid open-iscsi"
