When you deploy an application with Juju, juju status
will display the application status and the unit status, where the latter is represented by the status of its workload/charm and the status of its juju
agent (all marked in green in the picture below). This document clarifies all these statuses—their possible values as well as their meanings.
Contents:
Application status
As its name indicates, the application status reports on the status of each deployed application.
This status is the least common denominator of the workload statuses (see below) of all of the application’s units. So if all workloads are active, the application will also be active, but if even just one workload is blocked, the application will also be marked blocked.
The following figure provides an illustration of the status an application may be in at a given time, and lists the reasons for the transitions between different statuses:
Unit status
The unit status is given by the status of its workload/charm and the status of its juju
agent.
A unit’s status is usually expressed as <workload status>/<agent status>
, e.g. , active/idle
or unknown/lost
Workload / charm status
The workload / charm status reports the status of the charm(ed service):
Status | Meaning |
maintenance |
The charm is performing some (long-running) task such as installing a package or restarting a service. Or, the charm is still being setup (installed) and has had no chance to set its own status yet. |
waiting |
The charm is alive and well, and is waiting for some event to occur. No human intervention required. |
blocked |
The charm is stuck. Human attention/intervention is required. |
active |
The charm is alive and well. Everything’s fine. |
unknown |
The charm status is unknown. It may be still setting up, or something might have gone wrong. |
terminated |
The workload container is being destroyed, e.g. as a consequence of juju destroy-model . |
The workload status is generally speaking set by the charm (via e.g. self.unit.status = WaitingStatus('message')
). As such, its semantics is ultimately up to the user. However, the meanings we listed in the table above serve as guidelines (‘best practices’) for when a given status should be set.
Exceptions to this rule are terminated
and unknown
workload statuses: these are set by the juju agent and are not controlled by charm code.
Agent status
The agent status reports the status of the juju
agent running in the unit as it interacts with the juju
controller:
Status | Meaning |
allocating |
The charm pod has not come up yet. |
idle |
The juju agent in the charm container is not doing anything at the moment, and waiting for events. |
executing |
The juju agent in the charm container is executing some task. |
error |
The juju agent in the charm container has run but has encountered an uncaught charm exception. |
lost |
The juju agent is unresponsive, or its pod/container has unexpectedly come down. |
The agent status is determined and set by the juju
agent, so it cannot be directly controlled by the charm or a human operator.
Each newly deployed unit starts in maintenance/allocating
, quickly going to maintenance/executing
as the setup phase hooks are executed. If, by the time the install hook (if any) returns, the charm has set no workload status, the unit will go to unknown/idle
. So, in principle, at the end of the install event handler it should be clear if all went well (in which case the user should set active) or not.
