Hello!
@sed-i opened this issue in Charmcraft’s tracker requesting a new command in the tool that would apply a set of opinionated formatting choices in several charm files.
The idea is to be able to offer “aesthetic consistency” across charms, without making any semantic/functional changes.
The new charmcraft format command would rewrite several files in the charms’ project, applying the needed changes. Of course this will be totally optional, and the user may not want to use this command at all (in other words, this will not happen automatically on pack, for example)
So far we collected these actions on what such command would do:
- sort
metadata.yamlsections in a particular order; from metadata v2 reference:namesummarydescriptionmaintainerstermsmin-juju-versionseriesassumestagscategoriessubordinateprovidesrequirespeersextra-bindingsstoragedevicescontainersdeploymentresources
- sort
actions.yamlandconfig.yamlentries alphabetically - sort
charmcraft.yamlsections in a particular order:typecharmhubanalysisbases-
parts, and here inside try to sort them by order of business (need to check if that is possible)
- in all those
.yamlfiles: one line gap between each main section and no gaps anywhere else - in
config.yamloptions and inactions.yamlkeys and theirparamsitems: change names to be in kebab case (“foo-bar”)
Please comment below what other actions this command could have, thanks!!
