Abstract
The upload-charm-docs
GitHub action currently auto-generates the navigation table based on file hierarchy and alphabetical order of file names. To improve the flow of documentation, the optimal order of items on the navigation tab is not always alphabetical. Additionally, users need to include items in the navigation table which are not discourse posts and add hidden items so that they can be linked.
Rationale
This change adds support for users to customise the ordering of items on the navigation table to improve the documentation reader experience. This means that, for example, the getting started guide could be at the top whilst the technical reference would be listed later. Users can still chose not to customise the ordering and retain the default of alphabetical ordering. It also adds support for including links to pages other than discourse in the navigation table, such as a link to the charm actions. Finally, this change also adds support for items that should not appear on the navigation table but should be linkable from elsewhere.
Specification
Overview
The index.md
file will have an optional # Contents
section which will be interpreted as a contents index to other files within the documentation. This will be converted to the navigation table stored on discourse. *.md
files not in the list will be added in alphabetical order after any listed items for that folder. Items on the list that are commented out, will be interpreted to be unlisted items and will be added to the discourse navigation table without a level. After writing the navigation table to discourse, the equivalent contents section will be added back to the repository as a PR.
Contents Index
The following is an example for what the # Contents
section would look like and the resulting navigation table on discourse. index.md
# Contents
1. [Reference](reference)
1. [Actions](https://charmhub.io/nginx-ingress-integrator/actions)
2. [Configurations](https://charmhub.io/nginx-ingress-integrator/configure)
3. [Integrations](reference/integrations.md)
On discourse:
# Navigation
| level | path | navlink |
| 1 | reference | [Reference]() |
| 2 | charmhub-io-nginx-ingress-integrator-actions | [Actions](https://charmhub.io/nginx-ingress-integrator/actions) |
| 2 | charmhub-io-nginx-ingress-integrator-configure | [Configurations](https://charmhub.io/nginx-ingress-integrator/configure) |
| 2 | reference-integrations | [Integrations](/t/nginx-ingress-integrator-docs-reference-integrations/7756) |
There would be a few valid permutations of markdown lists, for example:
# Contents
a. [Actions](https://charmhub.io/nginx-ingress-integrator/actions)
b. [Configurations](https://charmhub.io/nginx-ingress-integrator/configure)
c. [Integrations](reference/integrations.md)
# Contents
* [Reference](reference)
* [Actions](https://charmhub.io/nginx-ingress-integrator/actions)
* [Configurations](https://charmhub.io/nginx-ingress-integrator/configure)
* [Integrations](reference/integrations.md)
# Contents
- [Reference](reference)
- [Actions](https://charmhub.io/nginx-ingress-integrator/actions)
- [Configurations](https://charmhub.io/nginx-ingress-integrator/configure)
- [Integrations](reference/integrations.md)
# Contents
The links can be 3 things:
- A local link to a directory (e.g.,
[Tutorials](tutorials)
which links to thetutorials
directory) - A local link to a file (e.g.,
[Getting Started](tutorials/getting-started.md)
which links to thetutorials/getting-started.md
file) - An external link (e.g.,
Items may be wrapped in <!-- ... -->
which is interpreted as the line is commented out and the wrapper is ignored when parsing the line.
*.md
and directories in docs
not listed in the contents index will be added in alphabetical order after any items that are listed. This is to ensure backwards compatibility.
References are checked for validity. A link to a file or directory that does not exist will result in an error. A link to an external reference that results in a non 2XX HTTP response to a HEAD
request will result in an error.
Translation to Discourse
- The list hierarchy indicates the level on the navigation table, this is checked against the file structure and results in an error/ warning to the user if it is not a match
- Files and directories don’t have to be listed, if they are not listed they are injected in the appropriate location after any listed items (for backwards compatibility and ease of use) in alphabetical order
- Commented out lines will appear on the navigation table without a level
Migration
The migration algorithm will be adapted to generate the contents index:
- Items without a level will be interpreted to be within the most recently encountered group with a level.
- Groups without a level will be ignored. This is because it is not clear what the purpose of a group without a level is and it is not possible to know whether any following items are intended to be within that group or a different group since the path is not guaranteed to include the group.
- This migration algorithm can be adapted in the future to look at the path to guess whether items should be within a group. This is not expected to be a frequent requirement (migration is only done once per project) and it is easy for users to correct any misinterpretations after the migration is complete.
Potentially Useful Markdown Libraries
A key requirement is to be able to interpret hierarchical markdown lists. None of the assessed markdown libraries seem to support this. The Python-Markdown
library was checked but doesn’t help with interpreting the hierarchy of list items:
print(test)
# Contents
>>> markdown.convert(test)
'<h1>Contents</h1>\n<ol>\n<li><a href="reference">Reference</a>\n a. <a href="https://charmhub.io/nginx-ingress-integrator/actions">Actions</a>\n b. <a href="https://charmhub.io/nginx-ingress-integrator/configure">Configurations</a>\n c. <a href="reference/integrations.md">Integrations</a></li>\n</ol>'
https://github.com/miyuchina/mistletoe produces:
# Contents
1. one
1. one one
2. one two
1. one two one
2. one two two
3. one three
2. two
3. three
"type": "Document",
"footnotes": {},
"children": [
{"type": "Heading", "level": 1, "children": [{"type": "RawText", "content": "Contents"}]},
"type": "List",
"children": [
"type": "ListItem",
"leader": "1.",
"prepend": 3,
"children": [
{"type": "Paragraph", "children": [{"type": "RawText", "content": "one"}]}
"loose": False,
"type": "ListItem",
"leader": "1.",
"prepend": 5,
"children": [
"children": [{"type": "RawText", "content": "one one"}],
"loose": False,
"type": "ListItem",
"leader": "2.",
"prepend": 5,
"children": [
"children": [{"type": "RawText", "content": "one two"}],
"loose": False,
"type": "ListItem",
"leader": "1.",
"prepend": 7,
"children": [
"children": [{"type": "RawText", "content": "one two one"}],
"loose": False,
"type": "ListItem",
"leader": "2.",
"prepend": 7,
"children": [
"children": [{"type": "RawText", "content": "one two two"}],
"loose": False,
"type": "ListItem",
"leader": "3.",
"prepend": 5,
"children": [
"children": [{"type": "RawText", "content": "one three"}],
"loose": False,
"type": "ListItem",
"leader": "2.",
"prepend": 3,
"children": [
{"type": "Paragraph", "children": [{"type": "RawText", "content": "two"}]}
"loose": False,
"type": "ListItem",
"leader": "3.",
"prepend": 3,
"children": [
"children": [{"type": "RawText", "content": "three"}],
"loose": False,
"loose": False,
"start": 1,
Which is not very helpful. Using markdown_it — markdown-it-py produces:
print(node.pretty(indent=2, show_text=True))
<root>
<heading>
<inline>
<text>
Contents
<ordered_list>
<list_item>
<paragraph>
<inline>
<link href='reference'>
<text>
Reference
<list_item>
<paragraph>
<inline>
<link href='https://charmhub.io/nginx-ingress-integrator/actions'>
<text>
Actions
<list_item>
<paragraph>
<inline>
<link href='https://charmhub.io/nginx-ingress-integrator/configure'>
<text>
Configurations
<list_item>
<paragraph>
<inline>
<link href='reference/integrations.md'>
<text>
Integrations
Contents Index Interpretation Algorithm
The required information from each list item is (1) the hierarchy, (2) the title of the link and (3) the value of the link. The hierarchy is needed to be able to validate the structure of the list matches the structure of the directory. Any list item line is generalised to: <comment>?<whitespace><leader><reference>
where:
<comment>
is optionally whether the line is wrapped with<!-- ... -->
whitespace
indicates the hierarchy by the number of characters, only spaces are supported, any other whitespace here will raise an exception -
leader
can be((\d\.)|(\*)|(-))\s*
reference
is basically some sort of link (local to a file or directory or a remote link)
There would be 3 kinds of lines, file
, link
and directory
directory
:- indicated by that the reference points to a local directory (the reference must resolve to an actual directory)
- Can be followed by any of the other items with a higher, equal or lower hierarchy
- If it is followed by an item with a lower hierarchy, keep track of the reference for inclusion in nested checks
link
:- indicated by that the reference points to a remote host (a HTTP request to that link must return a response that is not
4XX
which hopefully is2XX
or3XX
although could be5XX
) - Can only be followed by items at the same or lower hierarchy
file
:- Indicated by that the reference points to a local file (the reference must resolve to an actual file)
This is a classic recursive problem. The following data structure would keep track of items:
class ListItem(typing.NamedTuple):
Attrs:
hierarchy: The number of parent items to the root of the list.
reference_title: The name of the reference
reference_value: The link to the referenced item
rank: The number of preceding elements in the list at any hierarchy
hidden: Whether the item should not be displayed on the navigation table
hierarchy: int
reference_title: str
reference_value: str
rank: int
hidden: bool
Proposed algorithm:
- The base case is there is no new item, raise
StopIteration
- The non-recursive case is at a given
aggregate_directory
,hierarchy
(defaults to0
) andwhitespace_expectation
(defaults to the number ofwhitespace
characters at the root), the current item has the samewhitespace
count as the expectation and is afile
orlink
, yield the item - An error case is that the current item is a
file
orlink
at a higherwhitespace
count than the expectation and the previous item is not adirectory
, raise an exception - Another non-recursive case is that the current item is a
file
orlink
count than the expectation and the previous item is adirectory
, yield the item and updatewhitespace_expectation
with thewhitespace
character count of the item - The recursive case to go one level deeper is that the current item is a
directory
at the same hierarchy, yield the item and do a recursive call incrementing thehierarchy
and appending thedirectory
toaggregate_directory
and pass in the currentwhitespace_expectation
- The recursive case to go one level higher is for any item where the
whitespace
count is less than thewhitespace_expectation
, do not yield the item and return keeping the item to be processed
Matching Disk and Contents Index Items
The other piece is how to combine the index list with the disk list. This is maybe where a tree data structure would help, although I have been thinking about it an can’t think of how it could help in O(N) time. The following algorithm should be O(N).
We need a few data structures:
- List of all the
PathInfo
sorted byalphabetical_rank
- Iterable of
ListItem
sorted by their rank inindex.md
- A dictionary that has the
local_path
of thePathInfo
s with a value of whether the item has been yielded - A dictionary that has the
local_path
as a key and the respectivePathInfo
as the value - A dictionary with all the directories of
PathInfo
and their index into thePathInfo
list
The algorithm to get the PathInfo
in the correct order is:
- iterate through the
ListItem
and yield thePathInfo
using thelocal_path
toPathInfo
lookup. That lookup can only fail for remote links which will also need to be yielded. - Each time a
PathInfo
is yielded, mark it off in thelocal_path
to whether it has been yielded dictionary - Whenever a decrease in hierarchy of
ListItem
is detected, use the currentListItem
directory to lookup the starting index using the directory toPathInfo
index and yield items sequentially that have not yet been yielded whilst thePathInfo
still has the directory at the start of it path, mark them as yielded, then continue yielding items based onListItem
- Yield all the remaining
PathInfo
Execution Plan
- The contents index for items that only point to local files and directories
- Commented out items end up on discourse without a level
- Items on the contents index can point at other resources
- Migration to generate the contents index
- Action to create a PR for any items not on the contents index
- Checks that external references return a 2XX response on a
HEAD
request
Further Information
Link to the GitHub issue: https://github.com/canonical/upload-charm-docs/issues/26
