Common Gotchas
An incomplete summary of tips, tricks and gotchas to run Apache Spark on Kubernetes smoothly, even in small, local environments
- For
spark-client.spark-submitto work correctly, make sure DNS is enabled.- For example, if you are working with MicroK8s, run
microk8s enable dnsbefore submitting the spark job
- In case executor pods fail to schedule due to insufficient CPU resources, make fractional CPU requests
- Don’t forget to enable default Kubernetes config access for the snap, otherwise it will complain not able to find kubeconfig file even after providing the valid default kubeconfig file
- Make sure the namespace provided to
spark-submitis valid and the service account provided belongs to that namespace. To keep it simple, use thesetup-spark-k8sscript to create the account. - When working with k8s control plane url, please note that it has a prefix something like
k8s://https://
- Previous: Use the interactive shells
