I stumbled upon this openstack integrations charm and have it deployed but it just makes me sad.
I’m running Openstack Stein I believe and the latest CDK.
The example for the cinder storage stuff says: Warning ProvisioningFailed 14s (x22 over 4m50s) persistentvolume-controller storageclass.storage.k8s.io "cinder" not found
and the load balancer stuff is no happier. What have I missed?
And I’ve not a clue whats up with the loadbalancer, I’ve probably not setup something, but it doesn’t tell me what, I’m just trying to create an oldstyle Nova Loadbalancer setup
Okay, so the LB seemed to be caused by the misconfiguration in my charm network config so it couldn’t allocate the floating IP to the loadbalancer. I’ve also enabled the LB panel in horizon which is disabled by default to make it easier to see.
Awesome, glad you got it going. Please file an issue for anything the charm can do to help with that. Maybe in status messaging or in the readme updates.
Ah, the bugs were moved to Bugs : Openstack Integrator Charm a little while back and the charm store metadata wasn’t updated. I’ve corrected that now for all of the integrator charms.
Create storage classes for all clouds by johnsca · Pull Request #108 · charmed-kubernetes/cdk-addons · GitHub and it’s associated charm code was intended to have gone out with the last release, but unfortunately was missed. Doubly unfortunate is that the docs for that change were released, meaning there’s now a disconnect. We’re in the process of getting the docs fixed in a way that will allow them to update appropriately with the next release.
