This post is linked to this one [SOLVED] Creating a controller with Juju on Openstack . After I’ve made the bootstrap with this command:
$: juju bootstrap openstack-cloud --bootstrap-series=bionic --config network="Private Network IPv4" --config external-network="Floating Network IPv4" --config use-floating-ip=true --metadata-source ~/simplestreams/images --debug
and actived Juju Gui as shown below
$: juju gui
GUI 2.14.0 for model "admin/landscape-management" is enabled at:
https://10.20.81.227:17070/gui/u/admin/landscape-management
Your login credential is:
username: admin
password:
$:juju controllers
Controller Model User Access Cloud/Region Models Machines HA Version
maas-controller openstack admin superuser maas-cloud 3 1 none 2.5.4
openstack-cloud-RegionOne* landscape admin superuser openstack-cloud/RegionOne 3 1 none 2.5.4
I’ve created a new model
$: juju add-model landscape -c openstack-cloud-RegionOne
And run the deploy
$: juju deploy cs:apache2-26 --debug
15:01:44 INFO juju.cmd supercommand.go:57 running juju [2.5.4 gc go1.10.4]
15:01:44 DEBUG juju.cmd supercommand.go:58 args: []string{"juju", "deploy", "cs:apache2-26", "--debug"}
15:01:44 INFO juju.juju api.go:67 connecting to API addresses: [10.20.81.227:17070 10.1.0.13:17070 252.13.0.1:17070]
15:01:44 DEBUG juju.api apiclient.go:888 successfully dialed "wss://10.20.81.227:17070/model/e38f82ab-46f5-450f-8648-11034785ea67/api"
15:01:44 INFO juju.api apiclient.go:608 connection established to "wss://10.20.81.227:17070/model/e38f82ab-46f5-450f-8648-11034785ea67/api"
15:01:44 INFO juju.juju api.go:302 API endpoints changed from [10.1.0.13:17070 252.13.0.1:17070 10.20.81.227:17070] to [10.20.81.227:17070 10.1.0.13:17070 252.13.0.1:17070]
15:01:44 DEBUG juju.api apiclient.go:888 successfully dialed "wss://10.20.81.227:17070/api"
15:01:44 INFO juju.api apiclient.go:608 connection established to "wss://10.20.81.227:17070/api"
15:01:44 INFO juju.juju api.go:302 API endpoints changed from [252.13.0.1:17070 10.1.0.13:17070 10.20.81.227:17070] to [10.20.81.227:17070 10.1.0.13:17070 252.13.0.1:17070]
15:01:45 DEBUG juju.cmd.juju.application deploy.go:1306 cannot interpret as local bundle: bundle not found: cs:apache2-26
15:01:45 DEBUG juju.cmd.juju.application deploy.go:1415 cannot interpret as local charm: file does not exist
15:01:45 DEBUG juju.cmd.juju.application deploy.go:1245 cannot interpret as a redeployment of a local charm from the controller
15:01:45 DEBUG httpbakery client.go:243 client do GET https://api.jujucharms.com/charmstore/v5/apache2-26/meta/any?include=id&include=supported-series&include=published {
15:01:45 DEBUG httpbakery client.go:245 } -> error <nil>
15:01:45 DEBUG juju.cmd.juju.application deploy.go:1475 cannot interpret as charmstore bundle: (series) != "bundle"
15:01:45 INFO juju.cmd.juju.application series_selector.go:72 with the configured model default series "bionic"
15:01:45 INFO cmd deploy.go:1596 Located charm "cs:apache2-26".
15:01:45 INFO cmd deploy.go:1597 Deploying charm "cs:apache2-26".
15:01:47 DEBUG juju.api monitor.go:35 RPC connection died
15:01:47 INFO cmd supercommand.go:502 command finished
but checking its status I found this error:
code": 409, “message”: “Multiple possible networks found, use a Network ID to be more specific.”}}
$:juju status
landscape openstack-cloud-RegionOne openstack-cloud/RegionOne 2.5.4 unsupported 17:23:41Z
apache2 waiting 0/1 apache2 jujucharms 26 ubuntu
apache2/1 waiting allocating 1 waiting for machine
1 down pending bionic cannot run instance: failed to run a server with nova.RunServerOpts{Name:"juju-dfc1d0-landscape-1", FlavorId:"802e0d21-870f-4e1d-8e7a-4f70ab0166b4", ImageId:"1951d9a1-a227-426d-8012-6accf7898718", UserData:[]uint8{0x1f, 0x8b, 0x8, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xff, 0xec, 0x59, 0x79, 0x93, 0xa3, 0xb6, 0xb6, 0xff, 0xdf, 0x9f, 0x42, 0xcf, 0x49, 0xc6, 0x33, 0xcf, 0xc1, 0x2c, 0x6, 0xbc, 0xe4, 0xf6, 0xd4, 0xc3, 0x36, 0x76, 0x7b, 0xdf, 0xd7, 0x24, 0xd5, 0x25, 0x40, 0x60, 0x6c, 0x40, 0x18, 0x9, 0x6f, 0xc9, 0x7c, 0xf7, 0x57, 0x2, 0xf7, 0xf4, 0x32, 0xcb, 0x9d, 0x6c, 0x55, 0xf7, 0x8f, 0xdb, 0x55, 0x5d, 0xc2, 0x47, 0x47, 0x47, 0x47, 0x67, 0x91, 0x7e, 0x47, 0xfa, 0xce, 0xf4, 0x70, 0x6c, 0x71, 0x26, 0xe, 0x6c, 0xd7, 0xc9, 0xc0, 0x90, 0x3e, 0xf8, 0x6e, 0x14, 0xe1, 0xa8, 0xa, 0xb2, 0xd9, 0x8c, 0x81, 0x31, 0x35, 0x7d, 0xab, 0x9a, 0xe1, 0xc0, 0xef, 0x5c, 0x6, 0x80, 0x30, 0x72, 0x3, 0x6a, 0x83, 0xdc, 0xf, 0xe4, 0x97, 0x20, 0x7, 0x72, 0x9a, 0x79, 0x88, 0xdd, 0x8, 0x55, 0xab, 0x5b, 0x4a, 0xc3, 0x6a, 0x75, 0x14, 0xe1, 0xf3, 0xa5, 0x5a, 0xcd, 0x8a, 0x52, 0xa9, 0x20, 0x14, 0x84, 0x82, 0x98, 0x5, 0xd9, 0x46, 0x7b, 0xa2, 0xd7, 0x67, 0xd9, 0x9f, 0x32, 0x0, 0xbc, 0xe0, 0x26, 0xdf, 0xce, 0x6e, 0xff, 0x51, 0xd9, 0x4f, 0xdc, 0x1e, 0x36, 0xa1, 0xb7, 0xc5, 0x84, 0x7e, 0x9b, 0x26, 0xff, 0x8e, 0xdd, 0xfe, 0xa3, 0xb2, 0x9f, 0xb8, 0xab, 0xd5, 0x6f, 0xb4, 0xc6, 0x97, 0x19, 0xed, 0x2f, 0xcb, 0xcb, 0x81, 0xf7, 0x80, 0x47, 0xd4, 0xe4, 0x61, 0x48, 0xd9, 0x7f, 0x81, 0xb9, 0xb3, 0x60, 0xf1, 0x15, 0x85, 0xdb, 0xc5, 0xbb, 0x98, 0xb, 0xd9, 0x28, 0x8e, 0x20, 0x4a, 0xdd, 0xc0, 0x21, 0x19, 0x1c, 0xd3, 0x30, 0xa6, 0xd5, 0xc, 0x0, 0xd0, 0xf3, 0xaa, 0x20, 0xf7, 0x3b, 0xa0, 0x8, 0x1, 0xe, 0x2, 0xfe, 0x8, 0x23, 0xde, 0xc3, 0xe, 0x9f, 0x6, 0x85, 0x1b, 0xb8, 0x94, 0x4b, 0x99, 0xb, 0x1e, 0x76, 0x72, 0x99, 0x10, 0x9a, 0x7b, 0xe8, 0xa0, 0x87, 0x38, 0xb4, 0x20, 0x45, 0x55, 0x40, 0xa3, 0x18, 0x3d, 0x23, 0x3a, 0x11, 0xb4, 0x5e, 0x51, 0x9, 0x8b, 0x1d, 0x33, 0x8e, 0x3c, 0xd6, 0x84, 0x31, 0x67, 0x6e, 0x91, 0xb9, 0x47, 0x51, 0x86, 0x3, 0x46, 0xe4, 0x5a, 0xe, 0xe2, 0x62, 0xea, 0x7a, 0x84, 0x75, 0x26, 0x33, 0x3e, 0xfe, 0xa2, 0x7e, 0x7c, 0xce, 0x70, 0x20, 0x36, 0xe2, 0x80, 0xc6, 0x9c, 0xd, 0x83, 0x4c, 0x14, 0x7, 0xb7, 0x48, 0x24, 0x88, 0x2, 0xee, 0x8c, 0x32, 0x1c, 0x70, 0x3, 0x42, 0xa1, 0xe7, 0x1, 0xae, 0x1, 0x38, 0x1f, 0xa8, 0xb2, 0xc, 0x78, 0xb, 0x1d, 0xf9, 0x20, 0xf6, 0x3c, 0x90, 0x4b, 0xec, 0x41, 0x2e, 0x84, 0x22, 0xdf, 0xba, 0xb5, 0x7c, 0x62, 0xc, 0xd3, 0x43, 0x30, 0xe0, 0xc8, 0x36, 0xa6, 0x16, 0x3e, 0x5, 0x5, 0x82, 0xa2, 0xa3, 0x6b, 0xa2, 0xdc, 0x17, 0x62, 0x3c, 0x3, 0xc0, 0xcf, 0xf3, 0xc0, 0xa5, 0xbf, 0x66, 0x0, 0x68, 0x20, 0x62, 0x46, 0x6e, 0x48, 0x5d, 0x1c, 0xdc, 0x4d, 0x29, 0xe, 0x99, 0xf9, 0x40, 0x80, 0xe8, 0x9, 0x47, 0x7b, 0xe0, 0x6, 0x14, 0x45, 0x36, 0x34, 0x11, 0x1, 0x38, 0x0, 0x8f, 0xe2, 0x93, 0x51, 0x36, 0x8c, 0x3d, 0xda, 0x40, 0x21, 0xa, 0x2c, 0x14, 0x98, 0x2e, 0x22, 0x77, 0x36, 0xf4, 0x8, 0x62, 0xce, 0xb5, 0x29, 0x8a, 0xee, 0x6c, 0x37, 0x80, 0x5e, 0x81, 0xc2, 0xc8, 0x41, 0x34, 0xc3, 0x26, 0x9c, 0xa6, 0x3a, 0xb1, 0x39, 0x67, 0x97, 0x10, 0xdd, 0xe1, 0x0, 0x91, 0x2d, 0xa6, 0x19, 0x0, 0xf4, 0x33, 0x32, 0xa7, 0x14, 0x46, 0xf4, 0x8e, 0x27, 0x86, 0x1b, 0xf0, 0xae, 0xcd, 0x66, 0x61, 0xbe, 0xe3, 0x8e, 0x80, 0xe3, 0x6c, 0x1c, 0x99, 0x4c, 0xee, 0x94, 0xc2, 0xc0, 0x82, 0x91, 0x35, 0x4c, 0x9c, 0x77, 0x47, 0xe9, 0xe5, 0x19, 0x51, 0x67, 0xf9, 0x9d, 0xd0, 0xd8, 0x5c, 0xed, 0xd4, 0x88, 0x6c, 0xae, 0x25, 0xc, 0x28, 0xb2, 0x6a, 0x97, 0x97, 0xa, 0x1, 0xc0, 0xc2, 0xeb, 0xcf, 0xd8, 0x93, 0x67, 0x1a, 0xa6, 0xac, 0x26, 0xf5, 0x0, 0xa, 0xa0, 0xe1, 0xa1, 0x3f, 0x25, 0xe9, 0xeb, 0x9e, 0x4e, 0xa2, 0xd6, 0x35, 0x12, 0x21, 0x7c, 0x80, 0x3, 0x13, 0x15, 0xe8, 0x99, 0xb2, 0x71, 0xaf, 0x9c, 0xe9, 0x43, 0x73, 0xeb, 0x6, 0x88, 0x13, 0xaa, 0x42, 0x9, 0x8a, 0x50, 0x15, 0x25, 0x4e, 0x2a, 0x22, 0x91, 0x93, 0x95, 0x72, 0x85, 0x2b, 0x1b, 0xaa, 0xc1, 0xa9, 0x8a, 0x22, 0x9, 0x62, 0x59, 0x31, 0xd4, 0xb2, 0x91, 0x2e, 0xfb, 0xcb, 0xc2, 0x29, 0x22, 0x14, 0x70, 0x1, 0xc8, 0x7e, 0xdf, 0x99, 0x77, 0xe6, 0xf, 0xa3, 0xc9, 0xb0, 0x35, 0xd1, 0xa7, 0xd3, 0x87, 0x66, 0x23, 0xb, 0x7e, 0xff, 0x1d, 0xbc, 0x45, 0x67, 0x64, 0x82, 0xdf, 0x5e, 0xf7, 0x7d, 0x78, 0xff, 0x46, 0x7a, 0x7, 0xa4, 0xf7, 0x4f, 0xb, 0x78, 0xf3, 0x6, 0x30, 0xd6, 0xc, 0xf8, 0x3c, 0x33, 0x93, 0xf5, 0x9a, 0x7e, 0x27, 0x65, 0x38, 0x90, 0xfb, 0x19, 0x70, 0x28, 0xcd, 0xfb, 0x30, 0xc2, 0xb6, 0xeb, 0xa1, 0x82, 0xc5, 0x3f, 0xe5, 0x7b, 0x81, 0x6c, 0xc1, 0xaf, 0x6c, 0xf0, 0xa3, 0x11, 0x72, 0xbf, 0x4, 0xdf, 0x1, 0xcd, 0xb2, 0x90, 0x5, 0x8c, 0xb, 0x60, 0x8c, 0xbf, 0x4, 0x3f, 0x3, 0xce, 0x6, 0xd9, 0x44, 0xc6, 0xb3, 0x91, 0x6c, 0xfb, 0xc8, 0x66, 0x0, 0xf8, 0x95, 0xe9, 0x56, 0xf8, 0x42, 0xff, 0x2f, 0x41, 0x2e, 0x7, 0xde, 0xbf, 0xff, 0xaa, 0x2, 0xcc, 0x4c, 0xfe, 0xde, 0x72, 0x23, 0xc0, 0x85, 0xe0, 0xa5, 0x29, 0x3d, 0x6c, 0xee, 0x59, 0xaa, 0xbf, 0x75, 0xad, 0x5b, 0x9e, 0x83, 0x37, 0xef, 0x9f, 0xdc, 0xfa, 0x8e, 0x4d, 0x6d, 0x6e, 0x59, 0x70, 0xa7, 0xbd, 0xd5, 0x1b, 0xd3, 0xe7, 0xa5, 0xbc, 0x9a, 0x4, 0x3b, 0x49, 0x37, 0xdb, 0x57, 0x12, 0x11, 0xe4, 0x42, 0x3c, 0xec, 0x54, 0xa1, 0xe5, 0x7f, 0xc2, 0x60, 0xb8, 0xc1, 0xdd, 0x2b, 0x2f, 0x53, 0x8c, 0x3d, 0xc2, 0x4b, 0x5, 0xa5, 0x20, 0x73, 0x86, 0x8b, 0x3, 0xd7, 0xe4, 0xa0, 0x6f, 0xa9, 0xf2, 0x8b, 0xd5, 0x7c, 0x6f, 0xb8, 0x41, 0x86, 0x3, 0xc8, 0xdc, 0x62, 0x90, 0x6b, 0x22, 0xca, 0x22, 0xcb, 0x1, 0x9d, 0x78, 0x17, 0x3, 0xe8, 0xa0, 0x80, 0x82, 0x23, 0x8a, 0x88, 0x8b, 0x3, 0x90, 0xc8, 0x1, 0x36, 0x8e, 0x40, 0x2a, 0x4, 0xbc, 0x7f, 0xf3, 0x49, 0xc0, 0xb0, 0xcd, 0x47, 0xe2, 0x58, 0x3e, 0x6, 0x77, 0x62, 0x6, 0x80, 0xd3, 0xd6, 0xf5, 0x50, 0xb2, 0x91, 0xfe, 0x4, 0x2c, 0xcc, 0xe8, 0xec, 0xef, 0xe6, 0xc8, 0xac, 0x46, 0x29, 0xf2, 0x43, 0xa, 0xbe, 0xf, 0x0, 0xc5, 0x80, 0xe5, 0x8a, 0x87, 0xa1, 0x75, 0x9b, 0xd6, 0x70, 0x3, 0x18, 0xb9, 0x88, 0x0, 0x3b, 0xc2, 0x3e, 0xf8, 0x81, 0x14, 0xa, 0x85, 0x5f, 0x82, 0x2c, 0xc8, 0xa5, 0xe7, 0xc, 0xcf, 0x8b, 0x42, 0x41, 0x64, 0x7, 0xa8, 0x5c, 0x15, 0x4b, 0x42, 0x49, 0xe0, 0x7d, 0x6c, 0x21, 0x8f, 0x2f, 0xda, 0x2a, 0x14, 0x24, 0xd3, 0xe6, 0x54, 0x5b, 0x35, 0x39, 0x59, 0xaa, 0x40, 0xae, 0x6c, 0x23, 0x93, 0x33, 0x8b, 0x45, 0x4b, 0x2a, 0x5b, 0xb6, 0x29, 0x5a, 0xc2, 0x57, 0xec, 0x92, 0xea, 0xc7, 0xf6, 0x79, 0xc0, 0x91, 0xa9, 0x7d, 0x2, 0xb9, 0xcf, 0x2a, 0xf3, 0x5b, 0x1c, 0x79, 0xf, 0xc8, 0xb6, 0x91, 0x49, 0xdd, 0x23, 0xfa, 0xf0, 0x51, 0x75, 0x64, 0x55, 0xc1, 0xfd, 0x6c, 0x36, 0x2, 0x3f, 0xfc, 0xc6, 0xd4, 0x7c, 0x30, 0xb1, 0x85, 0x3e, 0xfc, 0x4, 0xa8, 0xeb, 0x23, 0xf0, 0xc3, 0x6f, 0xac, 0x79, 0xa0, 0x98, 0x42, 0xef, 0x3, 0xf9, 0x9, 0x10, 0xf7, 0xca, 0x88, 0xac, 0x79, 0x78, 0x1c, 0xff, 0x1, 0x18, 0x17, 0x8a, 0x58, 0x67, 0x88, 0x90, 0xc5, 0x7a, 0x59, 0xfb, 0xba, 0x9b, 0x27, 0x20, 0x7, 0x38, 0x6, 0x75, 0x2, 0x64, 0x52, 0x8e, 0x89, 0xc5, 0x31, 0x5, 0x92, 0x0, 0x38, 0x2e, 0xc0, 0x49, 0xc8, 0x82, 0xec, 0xff, 0x66, 0x1, 0xc7, 0xb9, 0x1, 0x41, 0x66, 0x1c, 0x21, 0xc0, 0xe1, 0xc4, 0xcf, 0xe9, 0xca, 0xd9, 0x86, 0x58, 0x70, 0xae, 0xff, 0xac, 0x29, 0x93, 0xdd, 0x80, 0xc5, 0x54, 0x56, 0x7b, 0x69, 0xc1, 0x27, 0x5b, 0x1, 0x12, 0x9b, 0x26, 0x22, 0xc4, 0x8e, 0x3d, 0xef, 0x52, 0xc8, 0xb2, 0x11, 0x46, 0x84, 0xe0, 0xfe, 0x6f, 0xd, 0x13, 0x49, 0x91, 0xa, 0xa2, 0xcc, 0x56, 0xf7, 0xdf, 0x38, 0xf9, 0xab, 0x71, 0xf2, 0x8f, 0xd8, 0xf2, 0x3f, 0x25, 0x50, 0x44, 0xa1, 0x20, 0x9, 0x85, 0xb2, 0x58, 0x90, 0xa4, 0xd2, 0x7f, 0x43, 0xe5, 0x6f, 0xd8, 0x52, 0xfe, 0x9, 0x6b, 0xfe, 0xd, 0xc1, 0x92, 0xe, 0x6f, 0x3c, 0x6, 0x87, 0xd, 0x5d, 0xf, 0x59, 0x3f, 0x82, 0x8, 0xd1, 0xe8, 0xc2, 0x4e, 0x3e, 0x37, 0x0, 0xa2, 0x42, 0xb2, 0x37, 0x6e, 0xe2, 0x21, 0x14, 0x2, 0x51, 0xb9, 0xfd, 0xc, 0xee, 0xbe, 0x7f, 0xfb, 0x36, 0xc8, 0x8b, 0xef, 0xde, 0x65, 0x0, 0xb0, 0x70, 0xc0, 0xd0, 0x3b, 0xd9, 0x42, 0x49, 0x51, 0x49, 0xec, 0x7f, 0xc6, 0x1e, 0xef, 0x53, 0x1a, 0x3b, 0x8d, 0x3f, 0x5d, 0x4d, 0x21, 0x1d, 0x99, 0xe1, 0x80, 0x13, 0xa1, 0x10, 0xe4, 0x2a, 0x48, 0x96, 0x2a, 0xa6, 0xa9, 0x1a, 0xa6, 0x59, 0x56, 0x14, 0x45, 0x82, 0xc8, 0x90, 0x4, 0x45, 0xb6, 0x54, 0xb9, 0x6c, 0x55, 0x4a, 0xb0, 0x5c, 0x52, 0x4b, 0xb0, 0x2, 0x65, 0xd5, 0xaa, 0x18, 0xa6, 0x5a, 0x2a, 0x57, 0xc, 0x5b, 0x40, 0x25, 0x51, 0x81, 0x2a, 0x54, 0x94, 0xb2, 0xaa, 0x8a, 0xb9, 0x6f, 0x99, 0xc, 0xa4, 0x90, 0x2e, 0x31, 0xc2, 0x8c, 0xa9, 0xa, 0x92, 0x52, 0x86, 0xa9, 0xef, 0xbb, 0xc4, 0x87, 0xd4, 0xdc, 0x66, 0x7f, 0x2, 0xe8, 0xec, 0x52, 0x20, 0xbe, 0x63, 0xe0, 0x10, 0x46, 0xe0, 0x7a, 0xb6, 0x3f, 0xb3, 0x36, 0xae, 0xfe, 0x88, 0x1d, 0x6e, 0xf9, 0xf7, 0x3, 0x1, 0xb9, 0xdf, 0xb2, 0x37, 0xb8, 0x90, 0xad, 0x66, 0x3f, 0x55, 0x22, 0xfb, 0x63, 0x36, 0x8e, 0xbc, 0x6c, 0x35, 0xfb, 0xf, 0x9e, 0x3c, 0xd9, 0x1f, 0xb3, 0xe9, 0x52, 0xb3, 0xd5, 0xec, 0x5f, 0xb5, 0x28, 0x93, 0xe5, 0x5e, 0x51, 0xb6, 0x2a, 0x55, 0x8a, 0x52, 0x45, 0x12, 0x4a, 0x1f, 0x58, 0x3e, 0xdf, 0x9c, 0xfa, 0x14, 0x72, 0xdc, 0xcd, 0x2e, 0x67, 0xfa, 0x1c, 0x58, 0xbd, 0x2, 0x63, 0x49, 0xd6, 0x13, 0xfe, 0x11, 0xba, 0x8b, 0x1f, 0xb, 0x35, 0x13, 0xd2, 0x4f, 0x1, 0xfa, 0x6b, 0xee, 0x94, 0x90, 0x0, 0xd6, 0x1c, 0xf8, 0xd7, 0xbf, 0x40, 0x4e, 0x1f, 0x36, 0x99, 0x2e, 0xdf, 0x31, 0x40, 0xe6, 0x43, 0xa, 0xa4, 0x82, 0x90, 0x1, 0x80, 0x42, 0xa7, 0xa, 0x3e, 0xe, 0x62, 0x31, 0xa, 0x29, 0xb4, 0xdc, 0xa8, 0xfa, 0x12, 0x6e, 0x66, 0x0, 0xf0, 0xb0, 0xf3, 0x8c, 0xfe, 0x8, 0x23, 0x1, 0xf0, 0x11, 0x8d, 0x5c, 0x93, 0x90, 0x10, 0x63, 0xef, 0xd3, 0x81, 0xfc, 0xad, 0x9b, 0xf5, 0x32, 0x90, 0xc7, 0xca, 0x88, 0xa7, 0x9, 0xbf, 0xad, 0x1c, 0xc9, 0x0, 0xb0, 0xc3, 0x6, 0x61, 0x65, 0x3b, 0x7, 0x3a, 0xd8, 0xb8, 0xc7, 0x84, 0xb2, 0xca, 0x94, 0x64, 0x0, 0xb8, 0xd5, 0xde, 0xd6, 0xc, 0x2f, 0xd2, 0x30, 0xaa, 0xa6, 0xb0, 0x33, 0x31, 0x93, 0x89, 0x22, 0x5a, 0x5, 0xbf, 0x27, 0xa9, 0xc8, 0xb1, 0xbf, 0x9a, 0xde, 0x6a, 0xf, 0x40, 0x5d, 0x9f, 0xcc, 0xda, 0xcd, 0x76, 0x5d, 0x9b, 0xe9, 0x9, 0x35, 0xe9, 0xef, 0xb7, 0xdb, 0x8d, 0x68, 0x56, 0xaf, 0x6b, 0xe1, 0xd2, 0xd1, 0x4e, 0xed, 0x9a, 0xe6, 0xb4, 0x17, 0x5a, 0xff, 0x3a, 0xea, 0x2b, 0x3d, 0x2d, 0x88, 0x8b, 0xbd, 0x63, 0xcb, 0x5f, 0xcd, 0x69, 0xf1, 0x5a, 0xf6, 0xa6, 0x4d, 0x55, 0xdb, 0x8e, 0xfa, 0x9a, 0xd0, 0xaa, 0x4f, 0xf, 0xad, 0x69, 0xdb, 0x28, 0x36, 0xc6, 0x7a, 0x2d, 0x11, 0x52, 0x3f, 0xcd, 0xb5, 0x7e, 0x4b, 0x3e, 0x37, 0x66, 0x5a, 0xaf, 0xe6, 0xc, 0x16, 0x35, 0xd, 0xcf, 0x6a, 0xad, 0x50, 0x84, 0xc1, 0xfc, 0xdc, 0xdb, 0x69, 0x24, 0xa5, 0xf5, 0xfb, 0x9d, 0x65, 0x42, 0xa3, 0x1b, 0x69, 0x11, 0x6f, 0x56, 0x9d, 0xad, 0xd5, 0x5a, 0xec, 0xdb, 0xfa, 0x20, 0x15, 0xd2, 0x6e, 0x6d, 0x8e, 0xa6, 0x5b, 0xa3, 0x86, 0x34, 0xf1, 0x8c, 0xba, 0xe6, 0xc2, 0x60, 0x71, 0xb0, 0xa6, 0xe2, 0x6e, 0x3d, 0x6d, 0x9f, 0x7b, 0x33, 0x2d, 0x4a, 0x85, 0xcc, 0x67, 0x9d, 0xd6, 0xc6, 0x1b, 0x34, 0xc6, 0xc5, 0xcd, 0xcc, 0x73, 0x7b, 0xb3, 0xed, 0x6e, 0xd8, 0x6a, 0xd3, 0x41, 0xab, 0x2f, 0x26, 0x42, 0x6, 0x75, 0x41, 0x5e, 0xef, 0xe6, 0x97, 0xde, 0xb2, 0xe9, 0xaf, 0xa5, 0x7e, 0x71, 0x38, 0x73, 0x8a, 0xeb, 0x6b, 0x73, 0x37, 0x6c, 0x68, 0xa8, 0x79, 0x12, 0xce, 0xc3, 0x99, 0x26, 0xf4, 0x77, 0xf3, 0xf3, 0x60, 0xd6, 0xbe, 0xf4, 0x77, 0x4d, 0xd8, 0x3c, 0x9, 0x97, 0xe1, 0x4c, 0x13, 0xfb, 0x8d, 0x76, 0x42, 0x4b, 0x6d, 0xb2, 0x6b, 0xc2, 0xff, 0xf4, 0xe5, 0xd4, 0xeb, 0xda, 0xb4, 0x7d, 0x6a, 0x8c, 0xd7, 0x9d, 0x2e, 0xde, 0xb4, 0xb7, 0x47, 0x73, 0xa0, 0x8d, 0xf5, 0x5a, 0x6d, 0xac, 0x35, 0x1c, 0x47, 0x1f, 0x69, 0xac, 0x7f, 0x8c, 0xeb, 0x89, 0x10, 0xc7, 0xd1, 0x6b, 0x5a, 0xe7, 0x7c, 0x14, 0x2f, 0x7b, 0x9c, 0xd7, 0xe0, 0x31, 0x5a, 0xea, 0xfc, 0xf1, 0x7e, 0x34, 0x6c, 0xc2, 0x76, 0xff, 0xba, 0x76, 0xae, 0x10, 0x95, 0x95, 0x61, 0x29, 0x14, 0xcb, 0x9d, 0x76, 0x43, 0x3e, 0x8, 0x6b, 0xe3, 0x38, 0xc4, 0x3, 0xbe, 0x64, 0x9b, 0x6d, 0xad, 0xa2, 0xad, 0xe1, 0x21, 0x11, 0x32, 0x96, 0xf3, 0xcd, 0x4b, 0x65, 0x38, 0x3a, 0xea, 0x92, 0xeb, 0x76, 0x2a, 0x5d, 0x3d, 0xef, 0xc8, 0xfd, 0x62, 0x4c, 0xe5, 0x7e, 0xb, 0xd3, 0x49, 0x74, 0x22, 0xfd, 0xf3, 0xe2, 0xd8, 0xe, 0xf3, 0x2b, 0xbd, 0x73, 0x6d, 0x8d, 0xd5, 0xe6, 0x50, 0xbb, 0x28, 0xd, 0x6d, 0x7a, 0xd5, 0xa7, 0xfd, 0x69, 0x77, 0x64, 0x5c, 0x53, 0x4d, 0xea, 0xd2, 0x5a, 0x91, 0x2f, 0xe1, 0x26, 0x8e, 0x5a, 0xa4, 0x38, 0xd6, 0xd7, 0x4d, 0xa2, 0xea, 0x23, 0xa7, 0xdd, 0x51, 0xe2, 0xb, 0xb2, 0xfa, 0xb3, 0x73, 0x14, 0x44, 0x3, 0xde, 0xac, 0x77, 0x49, 0x71, 0x49, 0xc, 0xb1, 0x48, 0x25, 0x45, 0x36, 0x6c, 0x73, 0x17, 0x68, 0x9b, 0x16, 0x1f, 0x76, 0x69, 0x22, 0x64, 0xd3, 0xe9, 0xb9, 0xbb, 0xca, 0xe4, 0x1e, 0xf3, 0xad, 0x9, 0xbd, 0x88, 0x6b, 0xc5, 0xef, 0x2f, 0xe, 0x51, 0x6b, 0x89, 0x4b, 0x41, 0xf3, 0xde, 0xbc, 0xd7, 0x6, 0x23, 0x5e, 0xd2, 0x77, 0xe5, 0x76, 0x7e, 0x6f, 0xb7, 0xf6, 0x5a, 0xd4, 0x3b, 0x2b, 0x25, 0x79, 0x74, 0x3e, 0xc2, 0xa0, 0x42, 0xca, 0x1b, 0xff, 0xd8, 0x48, 0x84, 0x94, 0xdd, 0xbd, 0x77, 0x81, 0x93, 0x65, 0xcf, 0xd5, 0xc2, 0x9e, 0x6, 0x7, 0x7e, 0xbd, 0xee, 0x77, 0x96, 0xb2, 0x7a, 0x90, 0x36, 0xd7, 0x43, 0xd3, 0x10, 0x2e, 0xd6, 0x78, 0x3b, 0x10, 0xf9, 0xcd, 0xa0, 0x39, 0x2d, 0x2e, 0xe, 0xf7, 0xf7, 0x45, 0xfb, 0x34, 0xa8, 0xc7, 0x87, 0xf0, 0x70, 0xd5, 0xa3, 0x92, 0x27, 0xd8, 0x89, 0x90, 0xe3, 0x5a, 0xe1, 0xcb, 0x52, 0x93, 0x1c, 0x24, 0xd1, 0xc3, 0x76, 0x31, 0x5a, 0xcd, 0x86, 0x82, 0xaf, 0xb8, 0x9d, 0xa3, 0x67, 0xd6, 0xb5, 0x93, 0xae, 0x69, 0x70, 0x50, 0xef, 0xeb, 0xda, 0xa9, 0xe1, 0xac, 0x1b, 0x8b, 0x89, 0x30, 0xd2, 0xc6, 0xf7, 0x7c, 0x4d, 0x1b, 0x37, 0x34, 0xa7, 0xbb, 0xef, 0x6b, 0xe5, 0x56, 0x22, 0x44, 0x13, 0xe7, 0x96, 0x7e, 0xd2, 0x6b, 0xfc, 0x69, 0xdc, 0xec, 0x6b, 0xfd, 0x9a, 0x66, 0x97, 0x4f, 0xf7, 0xe3, 0x64, 0xc0, 0xb0, 0x56, 0x5b, 0xeb, 0xcd, 0x5a, 0xab, 0x56, 0x5a, 0xc, 0x79, 0x33, 0xf2, 0x87, 0xe7, 0xc5, 0x62, 0xb9, 0x92, 0xfb, 0xca, 0x72, 0x21, 0x1a, 0xad, 0x62, 0xf7, 0x9e, 0x25, 0x63, 0x9a, 0x80, 0xcf, 0x32, 0x92, 0x25, 0xa3, 0x26, 0xb7, 0x6b, 0xda, 0x58, 0x2b, 0xce, 0x69, 0xd, 0xe9, 0xed, 0x55, 0x59, 0x1f, 0x2e, 0x63, 0xa7, 0xd8, 0x91, 0xea, 0xdd, 0x45, 0xd1, 0x6f, 0x1d, 0x2b, 0xbb, 0x85, 0x18, 0xd, 0x87, 0x83, 0x99, 0x2c, 0xd4, 0xf4, 0xf3, 0x7e, 0x98, 0x9e, 0xda, 0x70, 0xb3, 0x73, 0xda, 0x3b, 0xd1, 0x9e, 0xf1, 0x83, 0xa3, 0x6c, 0xf8, 0xc5, 0xae, 0x55, 0xac, 0xe5, 0x3b, 0xa5, 0x79, 0xeb, 0xba, 0x5f, 0xaa, 0x88, 0xa, 0x95, 0xda, 0x6e, 0x37, 0xf7, 0xb5, 0x65, 0x5b, 0xbc, 0x17, 0x25, 0xd3, 0xdf, 0xac, 0xc7, 0x3, 0xbe, 0x34, 0x59, 0x37, 0x23, 0xcf, 0xd3, 0xa2, 0xf9, 0x25, 0xb5, 0x89, 0x3a, 0x3e, 0xd5, 0x4e, 0xd1, 0x41, 0xde, 0x77, 0xf8, 0x6d, 0x3e, 0xec, 0x34, 0xb4, 0x45, 0x29, 0x1a, 0xce, 0x16, 0xed, 0x38, 0xc2, 0x13, 0xb5, 0x91, 0xcf, 0x5f, 0x50, 0x4b, 0xeb, 0x4d, 0xb5, 0x83, 0x79, 0xdf, 0x83, 0x75, 0x47, 0x1a, 0xcf, 0xc9, 0x75, 0xdf, 0x5e, 0xf9, 0x93, 0xd5, 0xd9, 0xd6, 0x5b, 0x73, 0x3a, 0x49, 0x84, 0xf8, 0x2d, 0x75, 0x5c, 0x32, 0xd6, 0xd4, 0x6f, 0xf0, 0xde, 0x76, 0x53, 0x53, 0xae, 0x78, 0xd4, 0x5f, 0x77, 0x37, 0x97, 0xf9, 0x28, 0x70, 0xf0, 0xba, 0x36, 0x21, 0x3b, 0x18, 0x1d, 0xbc, 0x50, 0xbf, 0xb4, 0x54, 0xcf, 0xb8, 0xce, 0x56, 0xbd, 0xae, 0xa8, 0x9b, 0x6e, 0xe5, 0xbe, 0xc6, 0xc3, 0xc3, 0xfa, 0x64, 0xa5, 0x9a, 0xf4, 0xfd, 0xe6, 0xc4, 0x8a, 0xfc, 0xe1, 0x48, 0x9a, 0xcc, 0x37, 0xfd, 0x93, 0xd7, 0xb, 0xce, 0x83, 0xb9, 0xba, 0xa9, 0x2f, 0xcb, 0xe6, 0xd1, 0x21, 0xe7, 0xd9, 0x40, 0xb, 0xf5, 0x70, 0x37, 0xf3, 0x48, 0x31, 0x18, 0xa, 0x11, 0x34, 0xc9, 0xb9, 0x29, 0x8e, 0x47, 0xcd, 0x91, 0x57, 0xdf, 0xef, 0xb7, 0xc1, 0x3c, 0x4d, 0x40, 0x4f, 0x5e, 0x48, 0x6a, 0x4b, 0xf6, 0xbd, 0xf1, 0xaa, 0xe9, 0x1f, 0x3b, 0x6d, 0x6b, 0x5f, 0xb2, 0x9d, 0xcb, 0xb0, 0x3e, 0x37, 0xe6, 0x6a, 0xc9, 0xf5, 0x2b, 0xc4, 0x1d, 0xd8, 0xfd, 0x59, 0xf3, 0x30, 0xde, 0xe5, 0xfd, 0xa7, 0xfd, 0x56, 0x1f, 0x34, 0x3e, 0xb7, 0xdb, 0x9a, 0x38, 0xa0, 0x11, 0xf6, 0x3c, 0x14, 0x55, 0x9f, 0x7d, 0x73, 0x25, 0x54, 0xb4, 0x2b, 0xb6, 0x5c, 0xe6, 0x24, 0xdb, 0x36, 0x38, 0x19, 0x96, 0x4c, 0xae, 0x2c, 0x9a, 0x6, 0x57, 0x56, 0x95, 0xa, 0x42, 0x50, 0x94, 0xad, 0x52, 0x89, 0x1d, 0x38, 0xec, 0xc8, 0xaf, 0xa6, 0xd, 0xf7, 0x2d, 0x27, 0x7f, 0x6, 0x0, 0x18, 0xba, 0xd0, 0xb2, 0x22, 0x44, 0x8, 0xba, 0x9d, 0x23, 0xaf, 0x80, 0x44, 0x42, 0x7b, 0x5d, 0xae, 0x3c, 0x32, 0xbe, 0x2, 0xa6, 0x19, 0x0, 0xb0, 0x67, 0x85, 0x90, 0x90, 0x13, 0x8e, 0xac, 0x2a, 0xd0, 0xf8, 0x71, 0x6b, 0xd8, 0xcd, 0x4b, 0x97, 0x99, 0xb6, 0x1d, 0x11, 0x53, 0xe9, 0xf9, 0xeb, 0x95, 0x93, 0xd7, 0x98, 0xf5, 0x8f, 0xd0, 0x8b, 0xd3, 0x19, 0x1, 0xd0, 0x5a, 0xfa, 0x60, 0xf6, 0x30, 0xd5, 0x27, 0x8b, 0x76, 0x5d, 0x7f, 0x18, 0x68, 0x7d, 0xbd, 0x9a, 0xdc, 0x45, 0x59, 0xdc, 0xf3, 0xf3, 0x17, 0x80, 0xfa, 0x70, 0x30, 0xd3, 0xda, 0x3, 0x7d, 0xf2, 0x30, 0x5b, 0x8f, 0xf4, 0xe4, 0x39, 0x82, 0x91, 0x47, 0x93, 0xe1, 0xa2, 0xdd, 0xf8, 0x48, 0xc5, 0x21, 0xa, 0x8, 0x85, 0xe6, 0x3e, 0xb1, 0x48, 0xe0, 0xe0, 0xe3, 0xe3, 0xf9, 0x97, 0x15, 0xa, 0x42, 0x96, 0x81, 0x57, 0x7d, 0xd8, 0x4c, 0xee, 0x81, 0x7c, 0x6c, 0x1, 0x41, 0x15, 0x84, 0x3f, 0x2, 0x19, 0x32, 0x1c, 0xf0, 0x2, 0xc0, 0x11, 0xf0, 0x29, 0x5e, 0x7a, 0x2d, 0x26, 0xc5, 0x55, 0x2f, 0x60, 0x4a, 0x7a, 0x37, 0x94, 0x5c, 0xd7, 0x7e, 0xbc, 0x1b, 0xba, 0x31, 0xdc, 0x8a, 0xab, 0xb7, 0xb7, 0x3b, 0xce, 0xd7, 0x16, 0x78, 0xf7, 0xa5, 0x5b, 0xa2, 0x67, 0x28, 0x89, 0xcd, 0xfc, 0x99, 0x5b, 0xd4, 0x67, 0x52, 0x3e, 0x81, 0x4a, 0xff, 0x7e, 0x8, 0x8f, 0xce, 0xc8, 0xe4, 0x8, 0x53, 0xb9, 0x40, 0xb6, 0x2f, 0x21, 0xd3, 0xff, 0xf0, 0x31, 0x89, 0x92, 0x3b, 0x5d, 0x14, 0x1c, 0x81, 0x1, 0xc9, 0x36, 0x93, 0x20, 0xa9, 0x29, 0xa2, 0x20, 0xe, 0x19, 0x32, 0x72, 0xdc, 0xc0, 0x29, 0x30, 0x38, 0x85, 0x63, 0x73, 0xfb, 0x68, 0xa0, 0x1b, 0x46, 0x7a, 0x32, 0x4d, 0xfa, 0x96, 0x0, 0x5e, 0x5e, 0xcd, 0xa5, 0xcd, 0x37, 0x8c, 0x79, 0xed, 0xc6, 0x2f, 0xb2, 0x26, 0xd7, 0xaf, 0xef, 0xdf, 0x7f, 0x1b, 0x9f, 0xf4, 0xfe, 0x8d, 0x98, 0xae, 0x66, 0x12, 0x7, 0x80, 0x6e, 0x11, 0x48, 0xaf, 0xfa, 0xd9, 0x6a, 0xbe, 0xee, 0xe8, 0xd4, 0x82, 0xb9, 0x8f, 0x8e, 0xe5, 0x38, 0x86, 0x1d, 0x39, 0xe6, 0xa6, 0x97, 0x3, 0x59, 0xa1, 0xf8, 0x38, 0xca, 0xb5, 0x80, 0xc8, 0x38, 0x91, 0x11, 0x3b, 0xaf, 0x43, 0xb4, 0xa4, 0x28, 0x7f, 0xc6, 0x55, 0x7f, 0xc2, 0xd7, 0xaf, 0x7e, 0x7f, 0xbc, 0x70, 0x7f, 0xee, 0xf5, 0xcf, 0x3e, 0x7e, 0xec, 0x9e, 0x6e, 0x39, 0x6d, 0x1c, 0xbd, 0x0, 0xce, 0xe9, 0x8b, 0x46, 0xea, 0xcd, 0xa7, 0x17, 0x84, 0x94, 0x7a, 0x7b, 0x2a, 0x79, 0x4d, 0xbe, 0x69, 0xc9, 0xc5, 0x4, 0x45, 0x1c, 0x41, 0x84, 0xe5, 0x2f, 0x79, 0x54, 0xe6, 0xf5, 0x7b, 0x48, 0xcf, 0xf5, 0x5d, 0x3a, 0x18, 0x36, 0xdb, 0x3d, 0xfd, 0x4e, 0x95, 0x5, 0x41, 0x78, 0xf9, 0x28, 0xf2, 0x47, 0xcd, 0x96, 0x1, 0x60, 0x82, 0x92, 0x1f, 0x77, 0x38, 0xe0, 0x58, 0x51, 0x1b, 0x47, 0x28, 0x3, 0xc0, 0x2c, 0xad, 0xe4, 0xa7, 0xc8, 0xbc, 0x2b, 0xa, 0xc2, 0x17, 0x1f, 0x4a, 0xfc, 0xd8, 0xa3, 0x6e, 0xa2, 0xf8, 0xc7, 0xe7, 0x9b, 0x8f, 0xee, 0x7c, 0xf5, 0xfa, 0xe1, 0xb9, 0xc1, 0xfe, 0xaf, 0xb9, 0xe5, 0x53, 0x99, 0x16, 0x44, 0x3e, 0xe, 0xb8, 0x8, 0xb1, 0x7a, 0xea, 0x2b, 0xf, 0x2e, 0x7f, 0xeb, 0xa4, 0x89, 0xb5, 0x5e, 0x6f, 0x58, 0x1f, 0xdd, 0xc5, 0x81, 0xe8, 0x73, 0x5, 0xfd, 0x9b, 0x37, 0x1f, 0xe9, 0x5f, 0xaf, 0xb3, 0x99, 0x2d, 0x93, 0x47, 0x43, 0x27, 0xc2, 0x71, 0x78, 0x3b, 0xa5, 0xa0, 0xe5, 0xa7, 0x6d, 0x6c, 0xb9, 0x38, 0xf9, 0x32, 0xad, 0x8, 0xa7, 0x34, 0xcb, 0x85, 0x1e, 0x8e, 0xe9, 0xed, 0x3b, 0x4c, 0x5a, 0xdb, 0xc3, 0x61, 0x78, 0x49, 0x3e, 0x3, 0x44, 0x2d, 0x74, 0x4c, 0x3e, 0x43, 0x2f, 0x76, 0x1e, 0xbf, 0x49, 0x6c, 0xa5, 0x82, 0x8e, 0xae, 0x85, 0x70, 0x52, 0xd7, 0x99, 0xfb, 0x87, 0xe4, 0x30, 0xb3, 0x6e, 0x2f, 0x98, 0x0, 0x4, 0xd0, 0x47, 0xd5, 0xdb, 0xf3, 0x43, 0x6, 0x0, 0xb2, 0x45, 0x9e, 0x57, 0x4d, 0xcd, 0x91, 0xec, 0x7e, 0x0, 0x10, 0xb2, 0xe5, 0x60, 0x4c, 0xb7, 0x38, 0x72, 0xaf, 0xc8, 0xe2, 0xf6, 0xe8, 0x72, 0xd3, 0x98, 0x75, 0x44, 0x4, 0x2, 0x4d, 0xd3, 0xb4, 0x5a, 0x71, 0x70, 0x85, 0x75, 0xf1, 0x62, 0x4a, 0x3a, 0xfb, 0xd9, 0xd0, 0xc6, 0x5a, 0x8d, 0x91, 0xb5, 0x71, 0xdd, 0x5c, 0xe5, 0x25, 0xa9, 0x11, 0x47, 0x7c, 0xeb, 0x5e, 0xe2, 0xd5, 0xba, 0xde, 0x55, 0x44, 0x6d, 0xe4, 0xf0, 0xbd, 0xd, 0x92, 0x94, 0xa1, 0x8f, 0xfd, 0x62, 0xbd, 0xab, 0x59, 0x53, 0x79, 0x72, 0x94, 0x97, 0xe7, 0xfa, 0xca, 0x3f, 0xcb, 0xe7, 0xfd, 0xb6, 0x9e, 0xef, 0xc5, 0x12, 0xae, 0xab, 0x7a, 0xc5, 0x5b, 0xc7, 0xdd, 0xfe, 0xae, 0x7d, 0xbc, 0x6c, 0x4d, 0x77, 0xda, 0x5d, 0x44, 0x3d, 0x65, 0x2f, 0xf0, 0xd, 0x89, 0x2f, 0xc9, 0xba, 0xba, 0x9b, 0x7a, 0xf5, 0xc5, 0xb1, 0xb8, 0x6f, 0x92, 0x32, 0x9c, 0x4c, 0x87, 0xf2, 0x7e, 0x60, 0xd4, 0x57, 0xcd, 0x8b, 0xb6, 0x3a, 0xd1, 0x3, 0xbc, 0xc6, 0xfc, 0x74, 0x58, 0xd2, 0xe7, 0x56, 0xc7, 0x6c, 0x56, 0xce, 0xbd, 0xf2, 0x42, 0xae, 0x8d, 0xc4, 0xa9, 0xd1, 0x3c, 0xf2, 0x33, 0xb8, 0x3f, 0x4f, 0xef, 0x87, 0x6d, 0xd3, 0x11, 0x21, 0x9e, 0xa, 0x2b, 0x67, 0x6e, 0xd9, 0x2b, 0xeb, 0x52, 0x5c, 0xec, 0xef, 0x77, 0x86, 0xcd, 0xeb, 0xa1, 0x3d, 0x94, 0xeb, 0xed, 0xba, 0x72, 0xba, 0xda, 0x44, 0x59, 0x29, 0xe4, 0xd0, 0xac, 0x98, 0xfa, 0xe0, 0x34, 0x35, 0x8f, 0xa2, 0x77, 0x2a, 0x2e, 0x8b, 0x7d, 0x7e, 0xe8, 0x6c, 0x35, 0x61, 0xb9, 0x97, 0xe3, 0xc6, 0x7e, 0x19, 0xfa, 0x91, 0x59, 0x97, 0x66, 0xbb, 0x19, 0xd1, 0x4e, 0x53, 0x77, 0x59, 0x93, 0x3d, 0xf7, 0xe8, 0x13, 0x3a, 0x23, 0xbd, 0xe9, 0x3d, 0xb1, 0x4a, 0x1a, 0xde, 0xe1, 0xcd, 0x5c, 0x51, 0xf9, 0xc6, 0x66, 0x49, 0xb4, 0xfc, 0x72, 0x30, 0xac, 0x63, 0x69, 0xbf, 0x37, 0x91, 0xbb, 0xe9, 0x4d, 0x47, 0xeb, 0x83, 0x50, 0x56, 0xfa, 0x93, 0xfd, 0x7c, 0x9b, 0xef, 0x4f, 0x50, 0x85, 0xf7, 0xe8, 0x6c, 0x6e, 0x74, 0x9b, 0x2b, 0x6c, 0x38, 0xe1, 0x68, 0xd0, 0x1d, 0x4f, 0x36, 0xb5, 0xb3, 0xb5, 0x9a, 0x6f, 0x24, 0x1b, 0x96, 0x87, 0xa6, 0x7a, 0xd9, 0xc, 0x27, 0xa1, 0xa7, 0xe, 0x6, 0x69, 0x59, 0xc0, 0xe, 0xdb, 0xea, 0xed, 0x55, 0xd1, 0x45, 0x1, 0x65, 0xbe, 0xf9, 0x3, 0x9e, 0x69, 0xe8, 0x93, 0x62, 0xdd, 0x8e, 0x4f, 0xfa, 0xd6, 0x9c, 0xea, 0xe3, 0xb2, 0x5d, 0x3e, 0x85, 0xb1, 0xb0, 0xea, 0x77, 0xd5, 0xb6, 0x77, 0x14, 0x90, 0x1a, 0x4b, 0x82, 0x5f, 0xa, 0x14, 0x65, 0x71, 0xda, 0x97, 0xba, 0xb4, 0x78, 0x2d, 0xe6, 0x3b, 0xb5, 0xbd, 0x9d, 0x5f, 0xae, 0x67, 0x87, 0xce, 0x8c, 0x9f, 0xe, 0x46, 0xf4, 0x4c, 0xc3, 0xfe, 0x49, 0xb2, 0xf2, 0xa5, 0xe5, 0xf6, 0x40, 0x95, 0x83, 0xb6, 0x22, 0xfd, 0x65, 0x7b, 0xb7, 0x98, 0x92, 0xf2, 0x9c, 0x4e, 0xee, 0x8b, 0xa3, 0xf5, 0xce, 0x1e, 0xc7, 0x7, 0xc3, 0x2e, 0xea, 0x66, 0x37, 0x32, 0x7d, 0xf5, 0x5a, 0x26, 0x82, 0x7b, 0xbe, 0xf6, 0x37, 0xfb, 0x4d, 0x94, 0xb7, 0xfc, 0xf9, 0xd0, 0xd8, 0xc7, 0xeb, 0x8d, 0xb9, 0x29, 0x99, 0x2a, 0x44, 0xb4, 0x73, 0x2d, 0xc5, 0x83, 0xc6, 0xe4, 0x5a, 0x12, 0xca, 0x93, 0x5e, 0xa7, 0x28, 0x39, 0xd2, 0x71, 0x7b, 0x6d, 0x96, 0x9d, 0x3d, 0xde, 0x9c, 0xb7, 0x2b, 0x7f, 0x7a, 0x56, 0x79, 0x67, 0x50, 0xd1, 0x55, 0xfe, 0x6a, 0x37, 0xd4, 0x68, 0x53, 0x2c, 0xe, 0xd0, 0x76, 0xee, 0x4e, 0xfd, 0xb0, 0xe2, 0xca, 0x9e, 0x34, 0x15, 0x25, 0xad, 0x7d, 0xc9, 0x37, 0xe4, 0x4e, 0x2f, 0x7f, 0xbc, 0xaf, 0x54, 0x3a, 0xfd, 0xf9, 0xc9, 0x1d, 0xec, 0x7d, 0xd5, 0xbc, 0x47, 0xa7, 0xce, 0xa8, 0x58, 0x52, 0x6b, 0xd3, 0x9d, 0x2f, 0x4e, 0x8d, 0xeb, 0x79, 0x19, 0x4f, 0x77, 0xfe, 0x41, 0x56, 0xf7, 0x43, 0xad, 0xde, 0xad, 0xd0, 0xb2, 0xc3, 0xa3, 0x61, 0x6d, 0x76, 0xbc, 0xf2, 0x79, 0x5a, 0xca, 0x37, 0xc5, 0x6, 0x3a, 0xd, 0xe6, 0xa7, 0x15, 0x5d, 0xc5, 0xdb, 0x99, 0x6d, 0x9e, 0xe9, 0x75, 0x21, 0xca, 0x8a, 0x53, 0x53, 0xea, 0x8d, 0xce, 0x6c, 0xb1, 0xe3, 0xe7, 0x72, 0xbb, 0xb5, 0x73, 0x9d, 0x8b, 0xaa, 0x4d, 0xa0, 0xb4, 0xec, 0x77, 0xce, 0x27, 0x7e, 0xa5, 0x69, 0xe7, 0xae, 0x16, 0x8d, 0x9d, 0xc1, 0x7c, 0xdc, 0x78, 0xf2, 0x4c, 0xe4, 0x9a, 0x5b, 0x18, 0x59, 0xc4, 0xa5, 0xdb, 0xff, 0xf3, 0x21, 0x24, 0x2c, 0x97, 0x62, 0xb, 0xa7, 0xc9, 0xa3, 0xf5, 0x7a, 0x77, 0x6f, 0xb5, 0x5e, 0xef, 0x1d, 0x18, 0xc, 0x47, 0xda, 0x74, 0xba, 0x6c, 0x54, 0xb5, 0x5e, 0x2f, 0xf3, 0xff, 0x1, 0x0, 0x0, 0xff, 0xff, 0xe3, 0xe1, 0xa2, 0x9b, 0xab, 0x22, 0x0, 0x0}, SecurityGroupNames:[]nova.SecurityGroupName{nova.SecurityGroupName{Name:"juju-7e3f9f48-2ffb-4a7c-81cb-8659eea14d77-3f6a02cf-6f6c-429a-8fec-c33d28dfc1d0"}, nova.SecurityGroupName{Name:"juju-7e3f9f48-2ffb-4a7c-81cb-8659eea14d77-3f6a02cf-6f6c-429a-8fec-c33d28dfc1d0-1"}}, Networks:[]nova.ServerNetworks{}, AvailabilityZone:"nova", Metadata:map[string]string{"juju-controller-uuid":"7e3f9f48-2ffb-4a7c-81cb-8659eea14d77", "juju-machine-id":"landscape-machine-1", "juju-model-uuid":"3f6a02cf-6f6c-429a-8fec-c33d28dfc1d0"}, ConfigDrive:false}
caused by: request (http://10.20.81.7:8774/v2.1/servers) returned unexpected status: 409; error info: {"conflictingRequest": {"code": 409, "message": "Multiple possible networks found, use a Network ID to be more specific."}}
