How to contribute
This document explains the processes and practices recommended for contributing enhancements to the SMTP Integrator operator.
- Generally, before developing enhancements to this charm, you should consider opening an issue explaining your use case.
- If you would like to chat with us about your use-cases or proposed implementation, you can reach us at Canonical Matrix public channel or Discourse.
- Familiarising yourself with the Charmed Operator Framework library will help you a lot when working on new features or bug fixes.
- All enhancements require review before being merged. Code review typically examines
- code quality
- test coverage
- user experience for Juju administrators of this charm. For more details, check our contributing guide.
Developing
For any problems with this charm, please report bugs here.
The code for this charm can be downloaded as follows:
git clone https://github.com/canonical/smtp-integrator-operator
To run tests, run tox from within the charm code directory.
To build and deploy a local version of the charm, simply run:
charmcraft pack
# Ensure you're connected to a juju model, assuming you're on amd64
juju deploy ./smtp-integrator_ubuntu-22.04-amd64.charm
Canonical contributor agreement
Canonical welcomes contributions to the SMTP Integrator Operator. Please check out our contributor agreement if you’re interested in contributing to the solution.
