How to configure SMTP
To configure the SMTP Integrator integration you’ll have to set the following configuration options with the appropriate values for your SMTP server by running juju config [charm_name] [configuration]=[value].
The SMTP server host needs to be specified as host. The rest of the configurations might not be needed depending on your SMTP server configuration.
For more details on the configuration options and their default values see the configuration reference.
