can. e setup a synology volume driver with microstack? It’s possible with openstack : https://docs.openstack.org/newton/config-reference/block-storage/drivers/synology-dsm-driver.html . But how to do it with microstack?
Possibly @openstack-charmers could help?
Hi @bchesneau,
While we don’t test external storage integration with MicroStack, the Cinder service is started such that it looks at the following directory for any drop-in config:
/var/snap/microstack/common/cinder.conf.d/<drop-in-file>.conf
Since the Synology driver is upstream, it is included in the Cinder package included in MicroStack:
/snap/microstack/current/lib/python3.6/site-packages/cinder/volume/drivers/synology
So what you could do is:
- follow their config guide and write a config file to put under
$SNAP_COMMON/cinder.conf.d/synology.conf; - restart the Cinder services
sudo systemctl restart snap.microstack.cinder-*.
I hope that helps.
