[In progress]
Install packages
sudo snap install jq
sudo snap install kubectl
pip3 install awscli --upgrade --user
Prepare VCA
AWS credentials
Add the credentials of your AWS account.
juju add-credential aws
You will be asked for the auth-type (choose access-key), access-key, and secret-key.
Enter credential name: aws-credential
Using auth-type "access-key".
Enter access-key: XXXXXXXXXXXXXXXXX
Enter secret-key:
Credential "aws-credential" added locally for cloud "aws".
Bootstrap Juju on AWS
Bootstrap the Juju controller, on AWS, which will be used to deploy Charmed Kubernetes.
juju bootstrap aws aws-vca --credential aws-credential
Deploy OSM VCA
The VNF Configuration and Abstraction (VCA) is a component required by Life Cycle Management (LCM), which is another OSM component. The VCA is an LXD bootstraped Juju controller that OSM will use to deploy proxy charms.
juju add-model vca
juju deploy cs:~charmed-osm/vca \
--constraints "mem=4G cores=2 root-disk=40G" \
osm-vca
juju offer osm-vca:osm-vca
Setup EKS Cluster
REGION=us-east-1
ZONES=us-east-1a,us-east-1b,us-east-1c
CLUSTER_NAME=eks-cluster
NODE_TYPE=t3.xlarge
STORAGE_GB=100
NUM_NODES=3
eksctl create cluster \
--name ${CLUSTER_NAME} \
--version 1.14 \
--nodegroup-name standard-workers \
--node-type ${NODE_TYPE} \
--nodes ${NUM_NODES} \
--nodes-min 1 \
--nodes-max 4 \
--node-volume-size ${STORAGE_GB} \
--node-ami auto \
--region ${REGION} \
--zones ${ZONES}
Add EKS cloud to Juju
- Update ~/.kube/config:
aws eks update-kubeconfig --name ${CLUSTER_NAME}
- Get Token:
aws eks get-token --cluster-name ${CLUSTER_NAME} | jq -r '.status.token'
- Get Certificate Authority Data:
aws eks describe-cluster --name ${CLUSTER_NAME} \
--query cluster.certificateAuthority.data
- Add EKS cloud to juju
CLOUD_NAME=eks-cloud
cat ~/.kube/config | juju add-k8s ${CLOUD_NAME} --local --region=aws/$REGION
juju add-credential ${CLOUD_NAME}
# Enter credential name: eks-cluster-cred
#Using auth-type "certificate".
#Enter ClientCertificateData: "LS0xxxxxxxxxxLQo="
#Enter Token:
Bootstrap K8s controller on EKS
juju bootstrap ${CLOUD_NAME} --credential eks-cluster-cred
juju add-model osm
Deploy Charmed OSM
juju deploy osm-ha
juju add-relation lcm-k8s aws-vca:admin/vca.osm-vca
juju add-relation mon-k8s aws-vca:admin/vca.osm-vca
