Security in Charmed Vault
- Built using a bare-bones, distroless Vault ROCK image which is regularly built and scanned for vulnerabilities
- TLS 1.3 encrypted communication amongst the Vault units, and any communication channels between clients the Vault server
- Policies that restrict the access of the Charm to only the essential operations
- Policies that restrict the access of credentials generated by the charm to the minimum set of operations needed.
- Canonical Observability Stack integration
- Audit logging
- Short-lived token TTLs
vault token create -ttl=5m
Handling Unseal Keys
When to use Auto-unseal
- Is fully trusted to handle the decryption keys of your Vault
- Has minimal downtime
- Has processes in place to ensure that new nodes can be unsealed promptly when necessary
