Secret events
Event > List of events > Secret events
See also: How to add a secret to your charm
Contents:
Complete list of secret events
  • secret-changed is emitted to the observer of a secret to notify it that a new revision is available.
  • secret-expired is emitted to the owner of a secret to notify it that the expiration time has been hit and a new revision should be created.
  • secret-remove is emitted to the owner of a secret to notify it that all observers have updated to a new revision and the old revision can be safely removed.
  • secret-rotate is emitted to the owner of a secret to notify it that the rotation time has elapsed and a new revision should be created.
Secret event triggers
Secret events can’t be directly triggered by Juju admin operations. Most other events occur because someone did something on the Juju CLI (created a relation, scaled something down, and so on); secret events are, however, exclusively triggered either by charm code or an internal Juju timeout (similar to update-status).
Secret events in ops
In ops, all secret events inherit from ops.charm.SecretEvent, which has a secret attribute that provides the Secret instance this event refers to. The Secret object has various attributes and methods that can be used to interact with the secret – see the API reference for details.
Great writeup @ppasotti.
Here’s something I drafted while reading the spec. Perhaps we could fit it in somewhere.
Concepts
Concept Hook tools Events Juju commands
Life cycle secret-add, secret-set, secret-remove secret-changed, secret-expired, secret-rotate, secret-remove
Access control secret-grant, secret-revoke
Payload secret-set, secret-get secret-changed show-secret
Identity
Table view
Secrets
Fieldname Possible values
Id (xid)
Description (string)
Last update
Expiry time Duration (“30d”) or RFC3339
Rotation policy never (default), hourly, daily, weekly, monthly, quarterly, yearly
Latest revision (uint)
Owner (aka scope?) app (default), unit, relation
Label (string)
Payload {k: v}
Last read revision
Id (xid)
Consumer (string)
Last read revision (uint)
We should go through this next week, I’m not 100% sure where it would fit. Maybe with @tmihoc?
Updated with the latest terminology and API changes, as well as various style tweaks.
