How to configure SAML
To configure the SAML Integrator integration you’ll have to set the following configuration options with the appropriate values for your SAML server by running juju config [charm_name] [configuration]=[value].
Two configuration values are mandatory, the SAML metadata URL that needs to be specified in metadata_url and the entity ID, in entity_id.
For more details on the configuration options and their default values see the configuration reference.
