Rockcraft extension 'fastapi-framework'
The fastapi-framework Rockcraft extension includes configuration options customised for a FastAPI application. This document describes all the keys that a user may interact with.
If you’d like to see the full contents contributed by this extension:
See How to manage extensions.
rockcraft.yaml > parts > fastapi-framework/dependencies: > stage-packages
You can use this key to specify any dependencies required for your FastAPI application. For example, below we use it to specify libpq-dev:
parts:
      stage-packages:
        # list required packages or slices for your FastAPI application below.
        - libpq-dev
rockcraft.yaml > parts > fastapi-framework/install-app: > prime
You can use this key to specify the files to be included in your rock upon rockcraft pack, in fastapi/app/<filename> notation. For example:
parts:
    prime:
       - fastapi/app/.env
       - fastapi/app/app.py
       - fastapi/app/webapp
       - fastapi/app/templates
       - fastapi/app/static
Some files, if they exist, are included by default. These include: app, app.py, migrate, migrate.sh, migrate.py, static, templates.
Regarding the migrate.sh file:
If your app depends on a database it is common to run a database migration script before app startup which, for example, creates or modifies tables. This can be done by including the migrate.sh script in the root of your project. It will be executed with the same environment variables and context as the FastAPI application.
If the migration script fails, the app won’t be started and the app charm will go into blocked state. The migration script will be run on every unit and it is assumed that it is idempotent (can be run multiple times) and that it can be run on multiple units at the same time without causing issues. This can be achieved by, for example, locking any tables during the migration.
