Review `powerflex-nova` for Listing
Hello, the powerflex-nova charm allows compute nodes to access the volumes created with cinder on a Dell PowerFlex storage system backend.
We would like to have this charm visible and searchable from Charmhub.
Can you please help us to have it reviewed?
Metadata links
CI Links
Documentation Links
Thanks @jproque15130 for the review request!
@dylanstathis can you please help with this review? You can go through and tick off the items on the checklist and post the result in this thread. This prior listing request could serve as an example of how to go about it.
Please ping me or anyone in Charm-Tech for any questions.
Hello Jean,
Thanks for waiting. I will proceed with this review next week.
@jproque15130 I will be starting the review tomorrow. One of the steps is a video call where you can explain the charm to me (does not need to be tomorrow). Please send me a message with your availability.
Would a demo be enough? https://www.youtube.com/watch?v=LgJia6QDTBc&ab_channel=DellTechnologies
My Juju OpenStack needs to be rebuild and I’m busy on other stuff as of now.
Yup that’s perfect. Thank you!
Hi @jproque15130
Thanks for submitting the charm. I have a few issues that need to be addressed before I can approve this charm for listing.
  • Links to at least the issue tracker are needed on Charmhub. Links can be specified in metadata.yaml.
  • The maintainer is listed in metadata.yaml as OpenStack Charmers <openstack-charmers@lists.ubuntu.com>. Is this correct?
  • The charm needs charmhub docs (Juju | How to add docs to your charm or charm bundle on Charmhub)
  • I am unclear on the release process. There does not seem to be any automation in place to release to unstable channels. According to the approval criteria, the charm needs to be released to an unstable channel before stable.
  • The charm does not clean up after itself. If the charm is removed, nothing happens. You need to implement the remove hook to uninstall the charm.
  • Test coverage is not good
  • Integration tests are not run as part of CI/CD
Once you address these issues, let me know and I can take another pass at reviewing the charm.
Hello,
  1. I’ve added a link to doc and source. I don’t understand what you mean by the issue tracker.
  2. @tony-meyer didn’t mention that point while reviewing our cinder charm. I’ve asked our IT to create a mailing list at dell for that purpose.
  3. Charm docs have been added to metadata-yaml
  4. This point in unclear to me too, can you elaborate and provide us some guidance on what exactly do I need to modify? (that’s our firs charm and we’re struggling a bit)
  5. @tony-meyer didn’t mention that point as well but clean up can take care of the removal of the connector file and the uninstall of the SDC debian package.
  6. What additional test do you want us to provide?
  7. I don’t get your point? what do you mean?
I assumed the contact point for the charm was indeed the OpenStack Charmers mailing list. If that isn’t the right one for the other charm, please do update it in that repo also.
I guess I’m more used to the K8s case, or where machines aren’t reused. I don’t recall any specific guidance on uninstalling things in the remove hook, but I guess it is cleanest for the case where a machine will be re-used. I’ll look into this more.
I’ve asked around, and this is something that’s going vary across charmers.
  • If you need to unregister or otherwise cleanup in remove (like dropping out of an HA system) then clearly the charm needs to do that.
  • A lot of (machine) charms don’t uninstall (e.g. snaps, debs) in remove.
  • It is tidy, and particularly if you have some reason to expect machine re-use then it’s probably worth doing, and also particularly if it’s fairly straightforward (like an uninstall command, without having to look for a bunch of other files).
  • It’s fine to bring it up in a review as a suggestion, but we don’t feel like it ought to block listing. If we have “tiers” of charms in the future, it might be a blocker for getting to higher tiers, but not for just being listed.
  • We definitely don’t want to encourage people spending large amounts of time figuring out how to perfectly clean up on remove, when, in the majority of the time, the machine will be removed anyway.
So, after some discussion, the charm does still need to clean itself up after removal as it is a subordinate charm and it is not expected that the machine goes away on removal.
To clean up, simply observe the stop hook. In that hook, uninstall any packages you have installed and delete any files you have created.
Ok let me take a look.
As an important side-note:
The charm is tested in an OpenStack environment with the Dell Powerflex system available outside the GitHub CI before the charm is pushed to a stable channel
I think this suggestion may have been wrong. I think it should be done in the remove hook instead.
Okay can you link to a list of the tests that are run? All I currently have to go off of is the one integration test which just deploys and does nothing else.
Sorry to do this, but I actually have another technical issue with the charm.
This charm relates to nova-compute charm over juju-info. The problem here is that juju-info is meant to be used to relate to any charm. But if you relate to any charm that is not nova-compute, this will not behave correctly. Rather than using juju-info, you should create a new interface that is supported by both powerflex-nova and nova-compute so that they can only relate to each other.
@benhoyt and I had a meeting with JP yesterday to get things closed off here.
The main points for here are:
  • I’ve opened a PR to do the uninstall on remove.
  • @billy-olsen recommended their use of the juju-info interface (I believe because it avoided having to do additional work elsewhere) and to look into developing a custom interface in the future. We do agree that it’s not great to use juju-info for this purpose, but Canonical recommended it, and it does work, and (no fault of Dylan’s) Canonical hasn’t done a great job supporting making and reviewing these charms, so we’re ok with it being listed as-is, and we’ll look towards helping improve this in the future.
The PR for cleaning up on remove has been merged, so all should be good here.
@adityagoel28 this one is good for listing, thanks!
Hi @tony-meyer ,
I have listed the package nova-dell-powerflex and it is visible now.
Thanks,
Aditya
