Request updating charm infor charm-cis-hardening
Hi, team,
could you please change “Submit bug” on the charm? How to update the description in general ?
Also what does it take for the charm to build from the new source in latest/edge and publish ? charm-cis-harden in Launchpad ?
Hello! The links and description are controlled through charmcraft.yaml file. The metadata is updated based on the revision on the first release and on any subsequent release on the default stable channel (by default, “latest” is the default track).
Ok, thank you.
It seems that I am missing access to publish. Will create seperate thread
$ charmcraft release -r29 --channel=latest/edge charm-cis-hardening
Credentials not found. Trying to log in...Opening an authorization web page in your browser.
If it does not open, please open this URL:
 https://api.jujucharms.com/identity/login?did=14e89e61ed1d2b54853a8d0408aeeabc4e0ea3cf4e7b14631571240bf4f409b3ID
Store operation failed:
- permission-required: No publisher or collaborator permission for the charm-cis-hardening charm package
Full execution log: '/home/mastier/.local/state/charmcraft/log/charmcraft-20260216-183719.953817.log'
