Hi folks!
I’d like to request guardrails for charms owned by the Kubeflow team (lp: ~kubeflow-charmers
We follow a ckf-major.minor
format (e.g. ckf-1.8
), so we need ckf-\d\.\d+
guardrails for:
mlmd
Thanks!
Hi folks!
guardrails for:
mlmd
Thanks!
Hi!
The guardrail has been added for the mlmd
package.
Best regards, Milos
Thanks @miloslu !
@dnplas , hi!
Are you sure ckf-\d\.\d+
is the right regexp for you? I see currently you have tracks like 1.14
and 1.0
which don’t match this pattern.
Hi @miloslu - I think there was an error in the guardrail:
{"error-list":[{"code":"invalid-tracks","extra":{"name":"ckf-1.9","package-id":"CeYeQZ1pzcBof8NsvF4ZlhPAPtyu6vNJ","package-type":"charm","track-guardrails":["cfk-\\d\\.\\d+"]},"message":"Invalid track name: ckf-1.9"}]}
There is a typo in it it should be ckf not cfk.
Hi @drednout yes, we have two patters, one is ckf-*
and the other is like 1.40
. Thanks for confirming!
@dnplas I added the correct guardrail, sorry for the typo.
Best regards, Milos
Perfect! This works! Thanks.
