Hello! Can we please rename library charms.istio_pilot.v0.istio_gateway_name to charms.istio_pilot.v0.istio_gateway_info? Thanks!
Daniela
Daniela
Renaming libs is not a trivial operation - they were not designed for that, and I wonder what’ll happen if you later want to revive gateway_name
or split the functionality of gateway_info
into more libraries again - which will be confusing to current and future users.
What happens if you just create a new istio_gateway_info
library? Or maybe move everything out and leave istio_gateway_name
as a mostly-deprecated stub with some message to that effect?
Another option is for you to upload the istio_gateway_info
library and then I can delete istio_gateway_name
- deletion is somewhat less risky.
If not, please let me know and I can do the rename for you, just be aware of the above
Sorry for the late reply, we have decided to delete istio_gateway_name
and create istio_gateway_info
Not a problem - let me know if you want me to hold until you’ve uploaded istio_gateway_info, or whether I’m clear to delete istio_gateway_name now.
it’s gone
