may I request the removal of the following charms from charmhub… I cannot keep these updated and don’t want the community to advertise something that is not ready or keeping up
Thank you
Thank you
Hi,
We don’t delete charms unless there’s a really good reason - in this case I would suggest closing all channels with charmcraft close
, and I can set it as unlisted so it becomes unfindable. It’s then unlikely anyone will be able to find it, and with the channels closed nobody will be able to install it.
Let me know if you’d like me to go ahead with the unlisting.
ah , new feature I was not aware of… thank you! will do
