Charmhub | Deploy Charmed MongoDB using Charmhub - The Open Operator Collection has the channel of dpe/edge which is no longer functional and has been replaced with 5/edge . We would love to get dpe/edge removed if possible. Thank you very much
Hi,
I think you can do this on your side - the correct procedure here is for you to charmcraft close mongodb dpe/edge. We do not delete tracks unless there’s a very good reason
- Daniel
awesome this is great info! Thanks for the help here @roadmr
Dear @roadmr,
Is it expected to see closed tracks in charmcraft status and received a proposals to use them?
ubuntu@taurus-dev:~$ juju deploy ch:mongodb
ERROR selecting releases: charm or bundle not found for channel "", platform "amd64"
available releases are:
channel "candidate": available series are: focal, focal, bionic, bionic, xenial, trusty, artful
channel "beta": available series are: focal, focal, bionic, bionic, xenial, trusty, artful
channel "edge": available series are: focal, focal, bionic, bionic, xenial, trusty, artful
channel "3/edge": available series are: focal, bionic
channel "5/edge": available series are: jammy, focal
channel "3.6/stable": available series are: focal, bionic
channel "3.6/candidate": available series are: focal, bionic
channel "3.6/beta": available series are: focal, bionic
channel "3.6/edge": available series are: focal, bionic
channel "dpe/edge": available series are: focal
Note, tracks dpe, 5.0, 3, latest are closed but still suggested above and reported here:
22:53:07 ✔ taurus:~$ charmcraft status mongodb
Track Base Channel Version Revision
latest - stable - -
candidate - -
beta - -
edge - -
3 - stable - -
candidate - -
beta - -
edge - -
3.6 ubuntu 18.04 (amd64) stable 97 97
candidate 97 97
beta ↑ ↑
edge 100 100
ubuntu 20.04 (amd64) stable 97 97
candidate 97 97
beta ↑ ↑
edge 100 100
5 ubuntu 20.04 (amd64) stable - -
candidate - -
beta - -
edge 109 109
ubuntu 22.04 (amd64) stable - -
candidate - -
beta - -
edge 115 115
5.0 - stable - -
candidate - -
beta - -
edge - -
dpe - stable - -
candidate - -
beta - -
edge - -
22:53:13 ✔ taurus:~$
Should this be officially bugreported? Tnx!
