according to naming conventions… I should NOT have used apache-
in the naming of my operator… so can I request this charm be removed and I will re-register with something else
Hi,
We don’t delete charms unless there’s a really good reason - in this case I would suggest closing all channels with charmcraft close
. I’m pretty sure it’s unfindable anyway so that should make it basically invisible, and you can register the correct desired name at any point.
- Daniel
