Request: please change the default channel for the following OpenStack, OVN and Ceph charms
Hi
Sorry, this is a bit of a big request, but we’d like to change the default channel for the OpenStack, Ceph, OVN and support charms:
  • OpenStack -> yoga
  • OVN -> 22.03
  • Ceph -> quincy
The detail:
OpenStack Charms
Please change the default channel for the following from latest to yoga:
  • aodh
  • barbican
  • barbican-vault
  • ceilometer
  • ceilometer-agent
  • cinder
  • cinder-backup
  • cinder-ceph
  • openstack-dashboard
  • designate
  • designate-bind
  • glance
  • glance-simplestreams-sync
  • gnocchi
  • heat
  • keystone
  • keystone-ldap
  • manila
  • manila-ganesha
  • masakari
  • masakari-monitors
  • neutron-api
  • neutron-gateway
  • neutron-openvswitch
  • nova-cloud-controller
  • nova-compute
  • nova-compute-nvidia-vgpu
  • nova-cell-controller
  • octavia
  • placement
  • swift-proxy
  • swift-storage
  • cinder-backup-swift-proxy
  • cinder-lvm
  • cinder-nimblestorage
  • cinder-purestorage
  • cinder-solidfire
  • cinder-netapp
  • cinder-three-par
  • ironic-api
  • ironic-conductor
  • ironic-dashboard
  • keystone-kerberos
  • keystone-openidc
  • keystone-saml-mellon
  • magnum
  • magnum-dashboard
  • manila-dashboard
  • manila-netapp
  • neutron-api-plugin-arista
  • neutron-api-plugin-ironic
  • neutron-api-plugin-ovn
  • octavia-dashboard
  • octavia-diskimage-retrofit
  • watcher
  • watcher-dashboard
OVN Charms
Please change the default channel for the following charms from latest to 22.03:
  • ovn-central
  • ovn-dedicated-chassis
  • ovn-chassis
Ceph Charms
Please change the default channel fro the following charms from latest to quincy:
  • ceph-dashboard
  • ceph-fs
  • ceph-iscsi
  • ceph-mon
  • ceph-nfs
  • ceph-osd
  • ceph-proxy
  • ceph-radosgw
  • ceph-rbd-mirror
Miscelaneous support charms
Please change the default channel (currently latest) for the following charms to:
  • hacluster - channel 2.4
  • mysql-innodb-cluster - channel 8.0
  • mysql-router - channel 8.0
  • percona-cluster - channel 5.7
  • rabbitmq-server - channel 3.9
  • vault - channel 1.8
  • openstack-loadbalancer - channel jammy
  • pacemaker-remote - channle jammy
Thanks very much!
Alex
Hello, tracks are updated, below is the full log.
3 failed do to the charm not having the track defined: keystone-openidc, watcher, watcher-dashboard
Let me know when those are created and contain a release and I will process them.
Set aodh default track to yoga
{'num_default_tracks_updated': 1}
Set barbican default track to yoga
Set barbican-vault default track to yoga
Set ceilometer default track to yoga
Set ceilometer-agent default track to yoga
Set cinder default track to yoga
Set cinder-backup default track to yoga
Set cinder-ceph default track to yoga
Set openstack-dashboard default track to yoga
Set designate default track to yoga
Set designate-bind default track to yoga
Set glance default track to yoga
Set glance-simplestreams-sync default track to yoga
Set gnocchi default track to yoga
Set heat default track to yoga
Set keystone default track to yoga
Set keystone-ldap default track to yoga
Set manila default track to yoga
Set manila-ganesha default track to yoga
Set masakari default track to yoga
Set masakari-monitors default track to yoga
Set neutron-api default track to yoga
Set neutron-gateway default track to yoga
Set neutron-openvswitch default track to yoga
Set nova-cloud-controller default track to yoga
Set nova-compute default track to yoga
Set nova-compute-nvidia-vgpu default track to yoga
Set nova-cell-controller default track to yoga
Set octavia default track to yoga
Set placement default track to yoga
Set swift-proxy default track to yoga
Set swift-storage default track to yoga
Set cinder-backup-swift-proxy default track to yoga
Set cinder-lvm default track to yoga
Set cinder-nimblestorage default track to yoga
Set cinder-purestorage default track to yoga
Set cinder-solidfire default track to yoga
Set cinder-netapp default track to yoga
Set cinder-three-par default track to yoga
Set ironic-api default track to yoga
Set ironic-conductor default track to yoga
Set ironic-dashboard default track to yoga
Set keystone-kerberos default track to yoga
Set keystone-openidc default track to yoga
ERROR: charmstore_migration.exceptions.APIError: ['Not all proposed tracks exist']
Set keystone-saml-mellon default track to yoga
Set magnum default track to yoga
Set magnum-dashboard default track to yoga
Set manila-dashboard default track to yoga
Set manila-netapp default track to yoga
Set neutron-api-plugin-arista default track to yoga
Set neutron-api-plugin-ironic default track to yoga
Set neutron-api-plugin-ovn default track to yoga
Set octavia-dashboard default track to yoga
Set octavia-diskimage-retrofit default track to yoga
Set watcher default track to yoga
Set watcher-dashboard default track to yoga
Set ovn-central default track to 22.03
Set ovn-dedicated-chassis default track to 22.03
Set ovn-chassis default track to 22.03
Set ceph-dashboard default track to quincy
Set ceph-fs default track to quincy
Set ceph-iscsi default track to quincy
Set ceph-mon default track to quincy
Set ceph-nfs default track to quincy
Set ceph-osd default track to quincy
Set ceph-proxy default track to quincy
Set ceph-radosgw default track to quincy
Set ceph-rbd-mirror default track to quincy
Set hacluster default track to 2.4
Set mysql-innodb-cluster default track to 8.0
{'num_default_tracks_updated': 0}
Set mysql-router default track to 8.0
Set percona-cluster default track to 5.7
Set rabbitmq-server default track to 3.9
Set vault default track to 1.8
Set openstack-loadbalancer default track to jammy
Set pacemaker-remote default track to jammy
Thanks very much! We obviously have some tracks missing, so I’ll look into them.
