Hello,
Could you please transfer ownership of the cve-service-k8s charm from myself to the Commercial Systems team? Then remove the unused and mistakenly named livepatch-cve-k8s-operator charm which is owned by Commercial Systems?
Many thanks,
Gabor
Hello,
Many thanks,
Gabor
Hi @gaborbk ,
I have transferred the ownership of cve-service-k8s to commercial systems team.
I don’t think we can delete/remove the other unused charm, but it is unlisted so it won’t appear publicly.
Thanks!
Aditya
Hi @adityagoel28 ,
Thank you very much for your help! Is there no way to delete the unused charm? As it’s only going to be used by internal users, they will still be able to find and view it, potentially causing confusion with the new charm.
Thanks, Gabor
Hi @gaborbk , sorry for the late reply.
We cannot delete the unused charm. There is one thing which you can do is to close all the tracks, with charmcraft close command. This prevents further releases to tracks and helps keep the charm’s listing clean and inactive. I hope that helps.
Thanks,
Aditya
I see, thank you Aditya!
