Hello,
Can you please make the magma-orc8r bundle as well as the magma-access-gateway-operator charm searchable and visible on charmhub?
Thank you,
Hello,
Thank you,
sure! It’s done.
Hello Daniel,
I don’t see them, is the change supposed to take some time to propagate?
No. But the charms don’t have any latest/stable builds and only charms which do are findable - once you release something to that channel they will be findable.
Ahh ok I wasn’t aware, the stable version of those charm is 1.6/stable. Thanks
